Fortyone.co.nz Daily Special
Postby Fortyone.co.nz » Fri Jun 29, 2007 3:56 pm
OK posts are valid for one day only! You have to secure your order the same day either with full payment or 50% deposit! PM me or preferrably email mac@fortyone.co.nz. Full receipts given of course, we're GST and Company registered! Full warranty on all parts offered!
Day 1 - June 29th 2007
Greddy E-manage - $465
Greddy E-Manage Ultimate - $845
Greddy V-Manage - $675
E-Manage Ultimate matching list:
http://www.trust-power.com/spec_swf/03e ... ltlist.swf
E-Manage matching list:
http://www.trust-power.com/spec_swf/03e ... gelist.swf
V-Manage details:
http://www.trust-power.com/03electric/vmanage.html
E-Manage Ultimate:
The GReddy e-manage Ultimate is as close to a stand-alone management system as you can get while maintaining the best features of a "piggy-back" engine management; an economical price, the usage of existing sensors, the ability to easily alter factory settings and not having to tune from scratch. But unlike the original e-manage, the Ultimate is more refined, requiring specific application usage (which we are constantly adding application updates that you can download FREE via greddy.com, Tech WebPages.) The benefit of this is, the included PC-based USB "Ultimate Support Tool" allows for even finer tuning capabilities, improved flexibility in fuel & ignition control and adds impressive data-logging qualities to make tuning quicker and easier. The increased number of input and output ports of the Ultimate, along with new built-in adapters add many new options to the unit. In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. The Parameter Set-up, tab menu format of the Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimate’s improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates. Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.)
E-Manage:
GReddy’s e-Manage is a cost effective programmable engine management system that allows you to properly tune your factory engine control without having to change the entire factory ECU system to an expensive "stand-alone" unit or the inconvenience of sending it out for a full ECU reprogram. The e-Manage system is a true universal "piggy-back" type unit that taps into most Japanese factory ECU wiring, by utilizing the vehicle’s existing sensors (or optional upgraded sensors if factory sensors are maxed out). The major benefit is the factory ECU settings become your "Base-MAP" for tuning. There is no need for extensive tuning for normal driving conditions, but does allow the tuner to fine tune, adjust for injector changes, and add new MAP(s) for situations the factory ECU is not capable of (like on-boost conditions). And as technological breakthroughs are achieved, we offer FREE updates via our greddy.com website’s Tech page. Basic functions will allow the tuner to slightly alter factory injector duty-cycle (± 20% at 5 preset RPM points) by intercepting and altering airflow or MAP sensor signals. An option for Honda VTEC cars will allow you to even adjust the VTEC shift point. Additional features are built into the system but are only accessible through the use of the e0-1, PRofec e-01 programmer or our PC-Windows based "e-Manage Support Tool" communication software (sold separately). There is a 16x16 airflow adjustment map, a maximum 50% larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging. With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 injector duty cycle map and the controls for adding up to 2 additional sub-injectors. If the "Optional Ignition Harness" and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well. If the factory range of map or airflow meter is surpassed, you can incorporate a larger airflow meter or our "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.)
V-Manage
The V-Manage, Variable Valve Timing Controller was designed by GReddy engineers to take advantage of some of the modern technology OE Manufactures* are now commonly incorporating into their latest engines. Based on the intuitive controls, datalogging and Maps of the e-manage Ultimate software, a tuner with a laptop computer, can now alter the factory’s ECU control of valve-timing at any RPM and load to optimize power output and fuel economy. However by purchasing GReddy's application specific V-manage Kits, you can simply "plug & play." V-manage Kits, include the V-manage, CD software, Plug-in Harness with adapter, and Pre-programmed MAP to optimise cam timing for increase horsepower, toque, and boost response.
(* Mitsubishi MIVEC, Honda iVTEC, Nissan CVTC, Subaru AVCS, Toyota VVTi,VVTL-I, Dual VVTi)
Last edited by Fortyone.co.nz on Sat Jun 30, 2007 11:25 am, edited 1 time in total.
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby Silent Knight » Fri Jun 29, 2007 3:59 pm
Do they come with the extra looms/harnesses or is it just for the ECU?
Silent Knight
Postby Fortyone.co.nz » Fri Jun 29, 2007 4:00 pm
Just the ECU Silent but the optional harnesses / parts are also available!
Fortyone.co.nz
Postby Fortyone.co.nz » Sat Jun 30, 2007 11:27 am
Today! June 30th 2007
HKS Super SQ Blow Off Valve - $395! Prices may vary depending on kit but the vast majority of kits are $395. This is for the model specific kits.
"HKS Super SQV (Super Sequential Blow Off Valve) uses a unique sequential valve structure and a differential pressure control system, which allows for a broad operation range from low boost to high boost."
Fitting List: http://www.hks-power.co.jp/products/blo ... _data.html
Fortyone.co.nz
Postby Fortyone.co.nz » Mon Jul 02, 2007 7:44 pm
Apexi Power FC
$1295
Matching List:
http://www.apexera.co.jp/carlife/pro_ap ... c_list.pdf
The Power FC proudly stands as A'PEXi's answer to the constraints and limitations associated with most piggy-back style fuel controllers. The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path. From multiple point fuel and ignition control to VTEC engagement (Honda applications) and boost settings, the Power FC is capable of accommodating even the most demanding performance enthusiasts.
Currently available exclusively through Power Excel Shops the Power FC replaces the factory ECU and controls all vital engine parameters (Off road use only, no OBD-II). Installation is as easy as replacing the factory ECU. (Some minor rewiring is required on select vehicles). The factory engine harness does not need to be replaced and all critical accessories such as air conditioning continue to function. By using the optional FC COMMANDER, the user can adjust and modify a wide range of settings. Since there is no need to upgrade ROM chips or modify ECU's, the factory ECU can be kept by the original user.
The Power FC operates off of three Main Menus. These menus are: Monitor, Setting, and ETC.
In Monitor Mode, the Commander can display up to 10 parameters of data in real time. Monitor Mode can display:
Engine RPM
Ignition Timing
Vehicle Speed
Air Flow Voltage (Pressure Sensor Voltage)
Injector Duty Cycle
Boost
Knocking Level
Battery Voltage
Intake Air Temp
Water Temp
In addition, there are 4 display patterns allowing 1-8 parameters to be shown on screen simultaneously. The data displays in numerical real time values with the option of a real time 10 second graph display. Peak Hold values and Display Hold functions only require the touch of a button. The Map Trace Mode allows Ghost Map Tracing of the Fuel Correction and Ignition Timing maps. This allows the user to visually see what point of the map is being used in real time. The Ghost Map Trace function leaves markers on the used portions of the map for easy reference.
Setting Mode allows full access to the 20x20 ignition timing and fuel correction maps. The user can adjust any portion of this map in 5x5 sections. Air flow correction values can be entered for vehicles upgrading air flow meters. Injector pulse correction menu is used when upgrading injectors. The Acceleration Enrichment Correction function improves response under hard and sudden acceleration. The Cranking Fuel Injection menu corrects the amount of fuel delivered when the engine is being cranked, or when the water temperature is cold. A separate Water Temp menu allows fuel correction according to water temperature. The RPM menu allows rev limiter settings and idle RPM levels. Access menus also vary according to specific applications. Rotary engine Power FC's accommodate leading and trailing ignition maps. Honda engines Power FC's allow for VTEC control. Complete boost control is possible by using the optional Boost Control Kit. Changing data is easy: just access the desired point on the map or data, and push the FC COMMANDER keys in the appropriate direction.
The ETC Menu contains utility parameters such as: version information, LCD screen brightness, and initialization of all data. In addition, the ETC Mode allows the user to monitor all factory sensors through one screen. This screen can tell the user if any sensor is in use or malfunctioning.
The Power FC also comes preprogrammed with several base maps. (Currently with Japan Domestic Market Vehicle Maps, minor initial tuning may be required. Please contact your authorized Power Excel shop for more information.) This makes the initial tuning process much quicker. As with all other fuel controllers, the POWER FC should be tuned on a dynomometer by a trained professional. A high grade air/ fuel ratio monitor is also recommended during tuning to ensure best results.
* CURRENTLY ONLY AVAILABLE THROUGH POWER EXCEL AUTHORIZED DEALERS
Please refer to our Dealers section for a complete list of Power Excel authorized dealers
FC COMMANDER (part of Power FC)
The FC COMMANDER is a hand held controller designed to allow access to the vital parameters within the Power FC. The unit allows a wide range of data modification through its large back lit LCD display. The unit has been designed so that one finger can control a wide array of data. Once connected, the A'PEXi logo will appear in the screen taking the user to the Main Menu. From here, the user can access the three Main Menus (Monitor, Setting, Etc.) The FC COMMANDER "communicates" with the Power FC control unit thereby creating one of the first interactive user friendly fuel management systems.
BOOST CONTROL KIT (part of Power FC)
The Boost Control Kit is an optional kit designed to control boost through the Power FC. Simple connection to the Power FC allows the user to access a full self-learning boost controller. The Power FC allows up to 4 different boost presets for any stage of driving. The high grade solenoid valve is the same one used in our Super AVC-R boost controller. As with the S-AVCR, the Boost control kit allows increased boost response and boost stability at high RPM's.
Fortyone.co.nz
Postby Fortyone.co.nz » Fri Jul 06, 2007 10:59 am
Cusco Clutch Disk and Cover
From $795 4-6 week delivery, or from $895 4-10 day EMS. This includes bolt on clutch disk (metal) and cover. Asbestos / other clutch options available.
Description:
http://www.cusco.co.jp/english/e_cont.html
Suit many Toyota's!
Fortyone.co.nz
Postby Silent Knight » Fri Jul 06, 2007 11:22 am
Don't suppose you can still do the SSQ for the price above? :P
Silent Knight
Postby Fortyone.co.nz » Fri Jul 06, 2007 11:28 am
Engine / chassis? =]
Fortyone.co.nz
Postby Silent Knight » Fri Jul 06, 2007 11:33 am
It's going on a 1JZ-GTE (JZZ30 Soarer) but I don't need a model specific kit. Going through a single turbo conversion so just need the BOV and the corresponding flange. :D
Silent Knight
Postby deaf_rattle » Fri Jul 06, 2007 11:34 am
what in the way of plumb back blow off valves can you do dude?
Postby Fortyone.co.nz » Fri Jul 06, 2007 11:40 am
Silent Knight wrote:It's going on a 1JZ-GTE (JZZ30 Soarer) but I don't need a model specific kit. Going through a single turbo conversion so just need the BOV and the corresponding flange. :D
Then the price is as stands =] Let me know what optional parts you need:
http://www.hks-power.co.jp/products/blo ... ption.html
deaf_rattle wrote:what in the way of plumb back blow off valves can you do dude?
Trust Type R?
http://www.trust-power.com/02turbo/blowoff_valve.html
Fortyone.co.nz
Postby Silent Knight » Fri Jul 06, 2007 11:44 am
Excellent, you are my hero. 8)
Hope you guys take credit card?
Just the BOV and same colored weld on flange thanks.
PM me what I need to do or how we organize the payment etc.
Cheers bud!!
Silent Knight
Postby deaf_rattle » Fri Jul 06, 2007 11:47 am
how much can you do the trust bov for? Cheers
Postby Fortyone.co.nz » Fri Jul 06, 2007 12:00 pm
Silent Knight wrote:Excellent, you are my hero. 8)
Cheers bud!!
Done. Matt - $385
Fortyone.co.nz
Postby Fortyone.co.nz » Mon Jul 09, 2007 2:24 pm
Work Emotion CR Kai - 17x7 Only
Standard colors: $1695!!!
Offsets: +47, +42, +32
Bolt Patterns: 4H-100, 4H-114.3, 5H-100, 5H-114.3
Every other size available, ask me for a special price!
Fortyone.co.nz
Postby Fortyone.co.nz » Tue Jul 17, 2007 9:59 pm
AEM Electronic Guages
Prices first:
Air / Fuel Controller and Gauge 2-in-1 - $625
Air / Fuel Gauge - $325
Fuel Pressure Gauge - (0-100psi) $345, (0-150psi) $360
Transmission Temperature Gauge - $240
Boost Controller and Gauge 2-in-1 - $485
Boost Gauge - (-30-50psi) $345, (0-150psi) $345
Oil Pressure Gauge - (0-100psi) $345, (0-150psi) $360
Oil Temperature Gauge - $240
Water Temperature Gauge - $240
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
    [li]Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers[/li]
    [li]Does not oscillate AFR reading like narrow band sensors[/li]
    [li]No laptop required for monitoring![/li]
    [li]Bosch sensor included[/li]
    [li]Accurate to 0.1 AFR[/li]
    [li]Reads in AFR or Lambda via a switch in back of gauge housing[/li]
    [li]24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio[/li]
    [li]Integrated three-digit display reveals AFR or Lambda in real time[/li]
    [li]User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system[/li]
    [li]Serial data stream included for output of AFR (RS 232)[/li]
Air / Fuel Gauge
AEM’s UEGO Display Gauge allows owners of AEM Wideband UEGO Controllers 30-2300 or 30-2301 to monitor Air/Fuel ratios (AFR) in real time without the use of a laptop. This gauge includes a 0-5 Volt analog output to interface with most data-loggers or aftermarket engine management systems, and includes an RS 232 serial data output port for data logging without an engine management system. AEM’s UEGO Display Gauge is calibrated to work with AEM UEGO sensor controllers ONLY. These units display to 0.1 AFR, feature 24 color-coded LED display lights for immediate reference to engine AFR, and have an integrated three-digit real-time display for AFR. AEM’s UEGO Display Gauge displays one channel only, so users wishing to display two channels simultaneously will need two gauges (V6 to V10 applications).
    [li]For use with AEM Wideband UEGO Controllers 30-2300 & 30-2301[/li]
    [li]24 color-coded LEDs and three-digit center display provide immediate reference to engine AFR[/li]
    [li]RS 232 Serial data output included for data loggers[/li]
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
    [li]No external interface required for programming![/li]
    [li]Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings[/li]
    [li]Quick connect technology eases the installation process[/li]
    [li]Two user selectable boost settings with peak boost memory[/li]
    [li]Scramble boost setting allows user to momentarily change boost levels[/li]
    [li]User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost[/li]
    [li]User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display[/li]
    [li]One (1) low-side output included for warning lights[/li]
Boost Gauge
AEM’s digital Boost display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
AEM’s digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels and black and white faceplates to personalize the look of your gauge—it’s like having four gauge designs in one!
    [li]Gauge pressure range -30-50psi and 0-150psi[/li]
    [li]Includes easy-to-install harness and sensor[/li]
    [li]Complete stand alone gauge requires no additional sensors or programs to operate[/li]
    [li]Ideal for both fuel injected and carbureted motors[/li]
    [li]LED displays provide precise reference to critical operating conditions and alert driver of potentially damaging operating conditions[/li]
    [li]Includes 0-5V analog output for routing to engine management system or data logger[/li]
    [li]Easy to read faceplates/displays are designed to complement existing AEM gauge styles[/li]
    [li]Included bezels and face plates allow you to personalize the look of your gauge[/li]
Oil Pressure Gauge
AEM’s digital Oil Pressure display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
    [li]Gauge pressure range 0-100psi and 0-150psi[/li]
AEM’s digital Temperature display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions. AEM’s digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels and black and white faceplates to personalize the look of your gauge—it’s like having four gauge designs in one!
    [li]Gauge temperature range 100-300F[/li]
Fortyone.co.nz
Postby blackie » Wed Jul 18, 2007 1:18 pm
man those AEM guages r the sex..
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1892
When my bros call.. dey get hit wit da chinnggggaayyy
blackie
Postby malc » Wed Jul 18, 2007 1:24 pm
Are you able to get any speedometers of any sort?
malc
Postby Fortyone.co.nz » Wed Jul 18, 2007 1:51 pm
Edit - Apexi - $560
More Info
The new A'PEXi DECS Tachometer combines the classic RPM, warning, and memory playback functions of the previous EL Tachometer with the real time temperature and pressure display of an EL II Meter. This completely redesigned unit uses the same EL (Electro-Luminescence) technology as the original EL Tachometer. Looking to combine as many aspects of engine monitoring into one unit as possible, A'PEXi designed this new tach to employ the new DECS (Dynamic Electronic Control System) technology. The DECS system integrates an optional pressure or temperature sensor to display real time values in a digital readout. Optional sensors that can be used in conjunction with the DECS Tach include: Water Temp, Oil Temp, Oil Pressure, and Fuel Pressure. Temperature values can be displayed in Fahrenheit or Centigrade. The DECS Tach also comes standard with a high intensity, dual stage shift light for accurate gear shifts.
Main Features Include:
    Large, 120mm analog display for easy to read shifting points.
    Digital display built into the gauge face
    Classic EL (Electro-Luminescence) lighting
    Accurate RPM reading all the way to 11,000 RPM
    Progressive number design for better high RPM viewing
    Integrated TEMP, and Pressure reading*
    High intensity shift light included
    Versatile mounting bracket
    Available in white and black face
* Temp, and Pressure reading available only with the use of an optional Temp or Pressure sensor. Sensors sold separately.
Fortyone.co.nz
Postby Fortyone.co.nz » Sat Jul 21, 2007 4:12 pm
Blox Racing Gauges
Blox Racing is an American Company which specialises in Honda parts, but offers universal parts as well. I believe I heard this correctly - they were listed as the 3rd most significant on-the-up automotive company in the US within the last 2 months. We, Fortyone Automotive, have been selling Blox for over a year now and we have had no, zip, zero, nil failures in their parts, and only rave reviews in return. Here's some deals on their universal items that will get you going for sure!
Blox Gauges
Universal 52mm design, gauge holders and adapters are available as listed below. Back-lit, clean looking. You can self install these yourself, but you might be a little better off finding a mechanic to do it for you. For the majority of cars out there, you should look towards finding your own place to install them, rather than looking for gauge holder options from Blox - however bing 52mm they should fit most other holders available. Quote: "The BLOX Racing series of 52mm gauges feature a classic look with a white background and green backlight. Each gauge is clearly marked and highly visible and comes with all the necessary mounting hardware and hose connections. BLOX Racing also offers enthusiasts an accurate RPM gauge."
52MM Boost Gauge (White - $65
52MM Vacuum Gauge (White) - $60
52MM Volt Gauge (White) - $60
52MM RPM Gauge (White) - $65
52MM EGT Gauge (White) - $190
52MM Oil Pressure Gauge (White) - $75 (must use adapter)
52MM Water Temp Gauge (White) - $75 (must use adapter)
52MM Oil Temp Gauge (White) - $75 (must use adapter)
Blox Liquid Filled Fuel Pressure Gauge Kit - $60 (Includes banjo bolt)
More information here! http://www.bloxracing.com/prod_gauges.asp
http://www.fortyone.co.nz
mac@fortyone.co.nz
64 4 566 1007
Night - Installed
Optional Equipment (you will need most of these to compliment the gauges above)
Water Temp Sensor Adaptor 28MM - Green - $19
Water Temp Sensor Adaptor 30MM - Blue - $19
Water Temp Sensor Adaptor 32MM - Light Blue - $19
Water Temp Sensor Adaptor 34MM - Red - $19
Water Temp Sensor Adaptor 36MM - Silver - $19
Oil Filter Block Adaptor (Oil pressure/Oil Temp) (Universal) - $40
Oil Filter Block Adaptor (Oil Pressure/Oil Temp) (Universal) (Gold) - $40
Adjustable Gauge Holder (52MM) (Small) - $15
Adjustable Gauge Holder (60MM) (Small) - $15
Adjustable Gauge Holder (52MM) (LG) - $20
Adjustable Gauge Holder (60MM) (LG) - $20
Blox-Banjo Bolt Adaptor (12MM Banjo 1/8" NPT) - $10
Oil Block Adapter Universal
Water Sensor Adapter
Oil Bolt 12mm / 1/8" NPT (adapts fuel pressure gauge to fuel filter)
Optional sensors and wiring harnesses available also!
Fortyone.co.nz
Return to Toyspeed Sponsors
