new DPR Electronic boost controllers - only $360+ !!!
Postby TWSTD » Wed Aug 29, 2007 12:58 pm
Just landed - the new DPR BCU eleconic boost controllers!
Check out the features - thats a lot of functrionality for only $360+gst (after toyspeed discount applied)
These superbly priced electronic boost controllers feature quality MAC solenoids and offer an extensive range of features usually found on far more expensive units!
Features include:
*Dual boost settings for user adjustable High and Low boost settings
*Realtime boost level display.
*Boost warn function to alert of overboost.
*Boost limit function to reduce boost when the warn function as activated and prevent engine damage.
*Adjustable gain to control the speed of boost build up.
*Start boost setting to adjust the boost level at which the controller starts to open the wastegate.
*Last boost and peak boost memory recall.
*Onboard system voltage display.
*User selectable display illumination colour change function.
*Built in Auto / Manual turbo timer functionality.
*External switching control (suitable to run other electronics such as NOS kits, intercooler sprayer kits etc.
*Altitude correction function.
*Supplied with mounting bracket for either surface or overhead mount, with a tilt of up to 20 degrees.
*Suitable for single turbo systems, twin turbo systems, internal wastegate control and external wastegate control.
As tested on our own race car!
Click the pic to go straight to our website. Rememebr you must notify us that you are a TS member when placing your order to obtain your discount!
Click here!
TWSTD
Return to Toyspeed Sponsors
