Clearance Sale - 4AGZE Limited Stock!
Postby 1I1 » Tue Mar 31, 2009 5:05 pm
Rods
AW11/Early AE92 $230 each - NO STOCK
Late AE92/AE101 $168 each
Pistons - $69 each
8.0:1 O/S 0.5mm - Only 2 left
8.0:1 Standard
8.9:1 O/S 0.5mm - Only 3 left
8.9:1 Standard
Ring Set
8.0:1 O/S 0.5mm - $168
8.0:1 Standard - $185
8.9:1 O/S 0.5mm - $168 - NO STOCK
8.9:1 Standard - $168
Also some Altezza parts:
Coils $405 each
AFM $310 (delivered)
Bonnet support clamp $66 (delivered)
All prices include GST and up to $12 to send within NZ.
As there is limited stock please check with me for availability.
Update: Stock update
TRD Clicky >>Here
1I1
Postby gepsk8 » Tue Mar 31, 2009 9:36 pm
how much are 8.9:1 O/S 0.5mm and rings normally?
O272754663
gepsk8
Postby 1I1 » Wed Apr 01, 2009 9:55 am
gepsk8 wrote:how much are 8.9:1 O/S 0.5mm and rings normally?
They have a RRP of $1580!
TRD Clicky >>Here
1I1
Postby Paulio » Wed Apr 01, 2009 3:26 pm
got rings for the 10.4:1 smallport?
yees booy
Paulio
Postby 1I1 » Wed Apr 01, 2009 4:08 pm
not_paul_from_waiheke wrote:got rings for the 10.4:1 smallport?
Can do a set - $168 + shipping
Mark.
TRD Clicky >>Here
1I1
Postby headshotnz » Thu Apr 02, 2009 12:19 am
Hey mate, need some rings for 20v silvertop.
Cheers :)
headshotnz
Postby 1I1 » Thu Apr 02, 2009 11:58 am
headshotnz wrote:Hey mate, need some rings for 20v silvertop.
Cheers :)
I would need to get a set of these in from Japan (3weeks). $205 + local shipping.
Mark
TRD Clicky >>Here
1I1
Postby Allister S » Tue Apr 07, 2009 2:02 pm
Hey can I get a set of std rings for a Bluetop?
AE82-9023839 ELMQF New Zealand GT. Also piston price Std size?
Thanks, Al
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Postby 1I1 » Tue Apr 07, 2009 5:04 pm
Allister S wrote:Hey can I get a set of std rings for a Bluetop?
Thanks, Al
The rings are not cheap, i would need to get them out of Japan - $320 delivered. Pistons would be $140 each, and just one in the country, the others would be x Japan.
Cheers,
Mark
TRD Clicky >>Here
1I1
Postby rx7guy » Tue Apr 07, 2009 5:15 pm
Hey how much for a set of rings and full gasket set for an ae111 20v blacktop?
Cheers, Aidan
The torque band is wide and the road is narrow
rx7guy
Postby Bling » Tue Apr 07, 2009 5:50 pm
rx7guy wrote:Hey how much for a set of rings and full gasket set for an ae111 20v blacktop?
Cheers, Aidan
Go here:
viewtopic.php?t=66290
This thread is for 4AGZE parts on clearance.
Postby frost » Wed Apr 08, 2009 10:24 pm
OMG $69ea for 4agze pistons is dirt cheap. im so contemplating buying a set just cos its a bargain
Postby slighty_sykotic » Sun Apr 12, 2009 1:46 pm
Yup,
I'll be in to see you on Wends Mark, ill grab 4x 8.9 o/s piston if you still have stock.
Bradley
slighty_sykotic
Postby gleem » Sun Apr 12, 2009 11:36 pm
so are the pistons an rods brand new and genuine toyota?
gleem
Postby Dell'Orto » Mon Apr 13, 2009 1:39 am
No, they're second hand aftermarket ones from a Toyota dealership :roll:
Postby 1I1 » Tue Apr 14, 2009 10:27 am
slighty_sykotic wrote:Yup,
Bradley
Sweet as Brad, need rings as well?
TRD Clicky >>Here
1I1
Return to Toyspeed Sponsors
