Intank Fuel Pumps - Aeromotive, Walbro, TRE
Postby Bazda » Wed Jul 20, 2011 10:46 am
Hey Guys,
I have been supplying intank fuel pumps for a little while now, mostly via trademe. These sell pretty fast so get in quick as there is only limited number of stock left!
I have 4 different models to choose from.
TRE Intank Pumps are an alternative to Walbro. These pumps have the same flow rates as a Walbro and have been verified by RC Engineering. The main point about these pumps is they are MUCH quitier than the Walbro units. These are manufactured in USA and are bought directly from TRE as we are the Distributor for TRE in NZ.
TRE 340LPH intank pump $200 incl GST
1 Year warranty
Same size as a walbro! this is good for 750hp at the crank.
A universal fit so some small modification may be needed.
TRE 255LPH Intank Fuel Pumps $140 incl GST
1 Year warranty
These are a direct OEM replacement pump as the Walbro units are. They flow very very similar to a walbro. There are 2 styles available 341 & 342.
Again the main point about these pumps is they are SUPER quiet.
I am running 2x of these in my Levin and I am amazed by the performance and quietness.
Walbro Intank $165NZD incl GST - Limited time only while stocks last as price will be going up to Retail of $190 incl GST
GSS341 & 342(Genuine pumps, not knock offs from China)
Aeromotive Stealth 340LPH Intank Pump $270NZD incl GST
If your into well known brands then this is the pump for your high HP car. Direct OEM replacement models 341 / 342 / 340. Supports up to 800hp at the crank!
Ethanol fuels ok.
Massive flow rates, much more than a Walbro and equiv to a Bosch 044
Postby iOnic » Wed Jul 20, 2011 7:27 pm
Got any external pumps? Definitely interested in a 340lph pump for the MR2 but I'm partial to the idea of getting one with a lower flow rate for the Corolla and both need to be external.
Postby Bazda » Wed Jul 20, 2011 7:47 pm
iOnic wrote:Got any external pumps? Definitely interested in a 340lph pump for the MR2 but I'm partial to the idea of getting one with a lower flow rate for the Corolla and both need to be external.
I can get inline external Walbro pumps both 190lph and 255lph.
They are around $220 incl GST
Or TRE external pumps 255LPH for $185 incl GST
Return to Toyspeed Sponsors
