Fortune Auto USA Coilovers 50mm Digressive
Postby Bazda » Thu Jul 21, 2011 10:21 am
Hi Guys,
MRP LTD is bringing to the NZ and Aus markets Fortune Auto USA coilovers for the first time.
Very popular coilover in the states, people are starting to learn who they are and what they do.
http://www.fortune-auto.net/shocktech.htm
http://www.facebook.com/FortuneAuto
These are like no other coilover currently on the market. They bring to us features not seen on others but at very good pricing. Assembled and valved in house at Fortune Auto USA. Custom valving is done to suit the car and the shock Dyno graph sheet provided.
#ATS Racing USA http://www.atsracing.net has started a partnership with Fortune Auto and is now installing these in their MR2s as they find the performance & ride quality to be up there with leading Euro Brands but for half the cost!.
#Again backed by AMS tuning in USA http://www.amstuning.com/
We are the Sole Distributor for Fortune Automotive for the NZ & Australia regions.
Why buy Fortune Auto Coilovers?
- Fortune Auto Coilovers are the best coilover you can buy in its price range.
- Fortune Auto valve and assemble their coilovers at their factory in the USA.
- Fortune Auto are suspension specialists, this is their full time job! The coilovers are not generic mass produced; they are made to customer’s orders and their needs.
- Custom valving is done to suit your car and your needs, whether it is for comfort, sport, race, drift applications.
- All shocks are dyno tested before being sent to you, they also provide you with the Dyno graph sheet!
- All Fortune coilovers are rebuildable back at their USA facility
- They use a specially designed Digressive 50mm shock piston (case diameter 57mm!), all other coilovers on the market use 44mm pistons! with 50mm cases.
- Comparable performance to KW, JIC etc.
Fortune Auto 500 Series Coilover
Fortune Auto 500 Series Vs Competitor - Check out the size difference! Another 7mm larger in diameter
DIGRESSIVE* All Fortune Auto shocks use a superior DIGRESSIVE piston. This technology allows for stiff, progressive (linear) damping at low stroke speeds. This helps to control vehicle body motion like roll, dive and squat. However at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
Check out the Features:
• Digressive 50mm piston mono tube design (57mm case diameter) providing superior shockabsorber performance (all others on the market use 44-45mm pistons and 50mm case diameters - much smaller).
• Custom valving is done to suit your car and your needs, whether it is for comfort, sport, or race applications.
• All shocks are dyno tested before being sent to you, they also provide you with the Dyno graph sheet!
• IP Synethic Shock oil for superior heat dissipation - We use 5w for most street applications and up to 10w for race
• Separate Nitrogen Chamber (floating) pressurized to 100-200psi depending on application and valving - This prevents cavitation in the shock oil
• USA made Shim stacks (5 shims usually used) depends on valving and application.
• Double O-ringed piston housing lids. 2 o-rings are used in case of o ring failures. We also use high performance o rings that are designed to be used with synthetic oil in high temperature environments.
• Floating ball nitrogen refill cap. This allows us to easily rebuild or revalve the coilover. Its also allows one to refill the nitrogen chamber with out taking apart the shock. This design is only found on fortune shocks.
• Compression blow off valve (for berms or rumble strips)
• S45C Chrome Piston Rod
• 30-way adjustable dampers
• Pillowball mounts - Noise Free! will last 50,000km before needing to be replaced
• Forged aluminum locking collars
• Cold Forged aluminium bottom mounts
• Height adjustment independent of preload
• ISO 9002 certification
***Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned their ISO certification.
Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers
Custom Spec Options
1. Your choice of drag, drift, street or track spec valving
2. Your choice of custom spring rates from 6k to 13k
3. **Adjustable camber plates included on MOST vehicle front coilover applications with Macpherson Strut suspension systems
RRP $1750 Toyspeed members - $1680 incl GST
We can get these for most makes & models.
Corolla - AE82/92/101/111
MR2 - SW20, AW11
Supra - JZA80
Lexus IS200 (Altezza)
IS300
GS300/400/ 430/JZS160L
SC300
Yaris
Mitsi Evos
Nissan S13/14/15
Honda EK, EG, DC2, S2000, Accord.
Subaru Sti, WRX, Legacy
Skyline GTR R32/33/34/35
Mazda RX7 FC/FD
BMW E36, E46, M3
Mini Cooper 02+
Nissan Primera P10
Nissan 350/370Z
VW MKII & III
Postby tsoob » Thu Jul 21, 2011 10:48 am
Bazz im so keen when you have them ready :)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Bazda » Fri Jan 13, 2012 9:09 am
How Fortune Auto Valve their shocks & R&D that goes into them - Shock Tech - Fortune Auto USA
Fortune Auto Time Attack - http://www.youtube.com/watch?v=ur33175OREU
Fortune Auto Rebuild & Valve Service - http://www.youtube.com/watch?v=AgTO0y51Niw
Postby Bazda » Thu Jan 26, 2012 11:27 am
Been having great feed back on the ride quality of Fortune Autos.
Having their ultra digressive valving makes for a nice ride over bumpy roads.
But still retaining all the performance gains for track use!
We have had guys swap out their JICs & Teins and saying their ride is now 10x better!
These cant be beaten for the price & specifications!
Postby Vertigo » Thu Jan 26, 2012 11:41 am
if only i had something in my piggy bank :)
TVIS just kicked in, yo!
Vertigo
Postby Bazda » Wed Mar 07, 2012 11:36 am
Been having great reviews from Customers on these.
They all cant stress how much the ride quality has improved over their previous coilovers.
These have been compared to the following brands - Ohlins & Cusco.
The shocks on the Fortune Autos will ride the bumps on NZ roads perfectly due to their digressive pistons.
Digressive piston technology FTW!
We will be able to get SW20 MR2 ones in a few months. These were designed for ATS in USA, specifically valved to suit the MR2. Development on these took quite a while but they managed to get them to ride perfect.
Postby Shrike » Wed Mar 07, 2012 4:40 pm
how are these vs your mrp range :p trying to decide on what brand ill go for when I get a set for just track ;)
Why dream it when you can live it
Shrike
Postby Bazda » Wed Mar 07, 2012 6:05 pm
Shrike wrote:how are these vs your mrp range :p trying to decide on what brand ill go for when I get a set for just track ;)
These will always have better shock valving. As Fortune Auto spend enormous amounts of time on development for the Digressive valving.
Postby Makaveli » Fri Mar 16, 2012 9:38 pm
Do you supply them for JZS147 Aristo? Also what spring rates do you recommend for street use mainly?
Makaveli
Postby Bazda » Fri Mar 16, 2012 9:46 pm
Makaveli wrote:Do you supply them for JZS147 Aristo? Also what spring rates do you recommend for street use mainly?
We can do them in our MRP coilovers.
Fortune Auto dont have a listing for the earlier Aristo. Only the later model one.
Postby Makaveli » Fri Mar 16, 2012 9:54 pm
How much?
Makaveli
Postby Bazda » Wed Mar 21, 2012 8:58 am
Pic of the Corolla versions with Swift spring upgrade!
Just installed into my car and what a difference!!
The digressive valving is something! feels like i've added aero to the F&R of the car. Wasn't expecting it to be this much better than what I was running.
Cant wait to hit the track next!
Return to Toyspeed Sponsors
