Sea Freight order for SMALL items
Postby Fortyone.co.nz » Tue Sep 06, 2011 7:04 pm
Right, at the moment we have containers being loaded for the oversized or heavy items out of Japan and the USA (think seats, body kits, hoods, exhausts, blocks, brake kits and so on). Whilst you can put any small item on this shipment, it works out cheaper to combine all small items into an ocean freight order, rather than paying volumetrically with a container. Example - 20 ARP head bolt kits would cost ~$120 on the container versus $60ish in a small box on the ocean. So there's savings to be had and with the US$ good for us, there's no better time to plan ahead.
This will therefore be a collective thread for small items to be shipped from the USA, on the ocean once all items are ready to ship. If your item is going to delay all other items, it will be shipped when it is ready at a later date. So essentially this is for items ready to ship within the next 3-4 weeks tops. The arrival for these items will therefore be the start of December at best. Remember, Ocean freight is subject to long delays because by default it takes weeks to ship, not days. So if you are in no rush, it's time for some deals to be had!
I will list all brands that I think will pique interest as I know many members here have other cars. Shipping for most items will be very cheap, under $10, even if it weighs 10kg+. Remember, some Japanese brands also sell in the US which we have access to as well, so I will list them too. No item is too small - so even if you want stickers from a brand, or a mug from another - it's all good!
Remember, it's targeted at small items. If the item you want is bulky or volumetrically (l x w x h) big, it'll be more expensive shipping wise.
Skunk2
All items including intake manifolds, exhausts, suspension, camber, shift parts, control arms, knobs, engine cosmetics, throttle bodies, thermal gaskets and so on. Excludes oversized items like Mufflers
Buddyclub
All items except aero, exhaust, seats. Includes control arms, manifolds, batteries, cams, valve train options, rails, interior parts, gaskets, electronics, brake pads, coilovers, camber arms, clothing. (Maybe wheels...*)
Braille Battery
All batteries - you can save about $30 here!
Blox Racing
Engine components (valvetrain, cams, retainers, springs, cam gears), wheel nuts and studs, intake kits, intake manifolds, exhaust manifolds, shift components, lower control arms, shift components, coilovers, universal mufflers, gauges, sensors and adapters, vaccuum manifolds, test pipes, valves, block guards, radiators and fans, throttle bodies, thermal gaskets, Fuel components, spherical bearings, traction bars, springs, sway Bars, roll center adjusters, springs, flanges, clothing
ASR
All braces and sway bar kits are fine!
APR Performance
Mirrors, splitters, carbon radiator panels, canards, strut bars
ARP Fasteners
All Bolts!
Turbonetics
Turbos, intercoolers, wastegates, clothing
Garrett
All Garrett
Sparco
Suits, Helmets, Gloves, Shoes, Harnesses, Steering Wheels and adapters, clothing, accessories, seat pillows. Basically everything but seats and harness bars!
AMS Performance
All items! I don't think there is much that is oversized, some heavy, but ask!
HKS
Electronics, Turbos, cams, valvetrain items, wastegates, blow off valve kits, gaskets, sprockets, universal mufflers, clothing, pistons / rods (block items), oil items, radiators, oil cooler kits, coilovers, brake items, intake, fuel items, clutch kits, fuel components, spark plugs and all other small HKS items!
5Zigen #
Accessories (stickers, clothing, cups), wheel nuts, manifolds, ARD racing gear
Tial
All Tial items!
Goodridge
All brake line kits!
Stoptech
Brake kits, rotors, pads, calipers, brake lines and brake fluids.
AEM
All AEM items. Can't name a single oversized item. Intakes, electronics incl ECU's, ignition, coil pens, fuel items and so on!
Advanced Clutch
All clutch kits, plates, covers, flywheels and bearings / tools.
Apexi ^
Electronics, gaskets, intake kits, filters, coilovers, universal mufflers, induction boxes, radiator caps, overflow tanks
Autometer
Gauges. What else?
Cusco #
All items - suspension, LSD, clutch, fluids, sway bars, strut bars, camber arms, rods, mounts, coilovers and so on!
Competition Clutch
Clutch stuff!
Deatschwerks / RC Injectors / Injector Dynamics / PTE / FIC
Injectors!
Edelbrock
Engine and intake components
DC Sports
Intake, manifolds and accessories
JE Pistons
Pistons, rings, rails, full sets or part sets - it's all good!
Carillo (CP) *
Rods, Cranks, Pistons, rings
Eagle
Rods, Cranks
EBC Brakes *
Brake pads and rotors.
Trust / Greddy ^#
All items including electronics, turbos, universal mufflers, pistons, rods, intake kits, intercoolers, induction systems (surge tanks, ducts), brake items, cams, turbo kits (because they are normally boxed small), oil cooler kits, adapters, gauges, blow off valve, wastegates, radiators, front pipes, radiator accessories (caps, breather tanks), coilovers, timing belts, strut bars, roll center adjusters, shift knobs, magnetic bolts, oil caps, fluids, clutch, NOS items (we do ZEX and NOS also!)
Innovative Mounts / Hasport / Drop *~
All mount kits, accessories, shift linkages and stays
Full-Race ~
All manifolds, turbo, kits, induction and so on.
K&N
Filters
Koni
All struts / shocks
Mizu / Mishimoto
Radiators, pipes, fans
MSD
All items
NGK
All items including wires, plugs
Nology
All Items
Energy Suspension *^~
All Items
Samco *
Hoses
Synapse *^~
(caution, slow) Wastegates, Blow Off Valves
Tanabe ^
Coilovers, strut bars, sway bars, springs
Hondata
Intake gaskets, ECU upgrades (already have a thread going)
Turbosmart
All items (I think)
Aeromotive
All fueling items
CP Pistons
All items!
Manley
All items!
Dart
Possibly the blocks, depending on space.
Cometic
All gaskets!
Gates
All belts
KW Suspension
Coilovers, accessories (like top plates, springs)
Moroso *~
Slow! Pans and so on!
Powerslot ^
Rotors
* indicates a brand known to be slow and therefore risks missing the first shipment
^ indicates a brand known to hold little stock and therefore risks missing the first shipment
~ indicates a brand known to make to order and therefore risks missing the first shipment
# indicates a US brand with Japanese parent who may not hold all same stock options as the Japanese parent
I may have missed some brands so always ask!
Mac
mac@fortyone.co.nz
http://www.fortyone.co.nz
Facebook: Here
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby MAC_HATER » Tue Sep 06, 2011 8:29 pm
im after a Type OS Cusco Front Strut Brace to suit JZA70 Supra? or would that be a bit big?
cant seem to find any in NZ so might as well ask :D
MAC_HATER
Postby Fortyone.co.nz » Tue Sep 06, 2011 8:54 pm
MAC_HATER wrote:im after a Type OS Cusco Front Strut Brace to suit JZA70 Supra? or would that be a bit big?
No strut bars are good to go! And it's cheaper via Japan anyways - $259
Fortyone.co.nz
Postby MAC_HATER » Tue Sep 06, 2011 10:30 pm
woo that sounds doable - thats outside of this thread though isint it? ill flick you a PM as ill be keen to get that :)
MAC_HATER
Postby Fortyone.co.nz » Tue Sep 06, 2011 10:41 pm
No problem! =D
Fortyone.co.nz
Postby Fortyone.co.nz » Wed Sep 07, 2011 1:52 pm
Today to whet your appetite - HKS. All prices delivered to your door.
HKS
Engine
HKS Cams - 4cyl from $349 ea
HKS Cams - 6cyl from $689 ea
HKS Cam Sprockets from $259 ea
HKS Head Gaskets from $199
HKS Valve Springs from $219
HKS Timing Belts from $239
HKS Oil Filters $29 + Courier
Intake
HKS Intake kits from $259
Electronics
HKS Meters from $239
HKS F-Con 3.3 $2099
HKS Turbo Timer 0 $155, 1 $229
HKS A/F Knock Amp $1329
HKS AFR $199 (D)
HKS EVC-6 $TBC
HKS EVC-S $535
Turbo
HKS Wastegate GT II $989
HKS SSQV4 BOV Universal $385
HKS Turbocharger from $2499
HKS Turbo Kits from $3190
HKS Intercooler Kits from $1546
HKS Intercooler piping from $335 (most are a lot more)
Suspension
Hypermax III from $2799
Drivetrain
HKS GD Pro Clutch from $1399
HKS GD Twin Plate from $2299
HKS Light Action clutch kit from $2499
Fortyone.co.nz
Postby Fortyone.co.nz » Thu Sep 08, 2011 10:04 am
Today - Buddyclub and Braille! Where to start!! I'll just dump out the lot, much is Honda, but there are Subaru / Nissan / Mitsubishi / Toyota bits (i.e. suspension, meters etc) also!
Buddyclub
Wheels
Lug Nuts $36 + Courier / set of 4
Racing SF Wheels from $219 / wheel
Racing SF Challenge wheels from $239 / wheel
F91 Kuroki Wheel from $259 / wheel
Chassis / Suspension
Front Camber Kit $290
Rear Camber Kit $195
Lower Control Arms short $355
Lower Control Arms long $369
D1 Damper Kits from $1699
N+ Damper kits from $1360 w/o mounts, $1699 w/ mounts
Exhaust
Racing Spec Damper from $2255 (most $2299 / $2399)
Racing Spec Manifold either $1335 or $1399
Universal muffler $269
Electronics
Secu-Timer $209
RSB-25 Battery $250
Digimeters $165 (water temp), $175 (Oil temp), $210 (Boost), $245 (Oil Pressure)
V-Con $95
Valvetrain
Evo 8/9 264 $399ea, 272 $439ea, 280 $460ea
Honda B III+ $469ea, IV $510ea, VI $539ea
Honda K I $899, II $1025, III $1025, N+ $1189
Cam Gears - B Series - $269 pair
Cam Gears - K Series - $525 pair
Gasket 0.5mm B-Series $125
Gasket 2.0mm B-Series $269
Valves B-Series IN or EX $249 / set
Retainers B-Series $415 (w/o coating), $455 w/ coating
Retainers K-Series $455
Valve Springs B-Series $319, K-Series $319
Brake / Transmission
Brake Pads from $135 / pair
Final Gear Set K20A 5.46 $1255
Interior / Accessories
Quick Shift Kits from $149
Rad Caps from $29 + Courier
Oil Caps from $55 + Courier
Shift knobs from $49 + Courier
Braille Battery
B106 3.1kg 527PCA, 283CA, 210CCA $249
B129 4.3kg 813PCA, 436CA, 323CCA $259
B14115 5.2kg 904PCA, 486CA, 360CCA $265
B2105 6.8kg 1067PCA, 574CA, 426CCA $279
Fortyone.co.nz
Postby Fortyone.co.nz » Fri Sep 09, 2011 12:15 pm
Today - Sparco + Advanced Clutch
Sparco - http://www.sparcousa.com/
Advanced Clutch - http://www.advancedclutch.com
Sparco
Helmets from $599
Steering Wheels - Competition from $355
Steering Wheels - Street from $259
Steering Wheel hubs from $109
Shift knobs from $99
Race Pedals from $49
Race Harnesses from $355
FIA Harnesses from $489
Steet Harnesses from $159
Race Suits from $299
Race Shoes from $155
Race Gloves from $99
Advanced Clutch
Inline 4 Clutch kits from $599 (Clutch and Cover)
Boxer 4 Clutch kits from $699 (Clutch and Cover)
6Cyl Clutch Kits from $699 (Clutch and Cover)
Fortyone.co.nz
Postby Fortyone.co.nz » Fri Sep 09, 2011 1:05 pm
Sneaky one -
RC Engineering
Peak Hold
155cc-270cc $89 ea
320cc-370cc $99 ea
550cc-1200cc $111 ea
1600cc $191 ea
Saturated
195cc-240cc $89 ea
310cc-440cc $99 ea
550cc-750cc $111 ea
Courier +$7
Fortyone.co.nz
Postby Fortyone.co.nz » Mon Sep 12, 2011 10:51 am
Today I'll throw up the common ARP options for all chassis's:
ARP
Nissan L20 4-cylinder head stud kit $170
Datsun A-12 12pt head stud kit $156
Datsun A-14 12pt head stud kit $155
Nissan L24 L26 L28 series head stud kit $232
Nissan GTR RB26DETT ARP2000 head stud kit $455
Nissan RB20, RB20DET, RB25, RB25DET head stud kit $222
Nissan CA18DE, CA18DET head stud kit $162
Nissan Pulsar GTiR SR20 DET 12mm head stud kit $211
Nissan VQ35 12pt head stud kit $298
Nissan CA16&18DE, CA16&18DET undercut studs head stud kit $187
Nissan L20 main stud kit $152
Nissan SR20DET main stud kit $158
Nissan L24 L26 L28 series 6-cylinder main stud kit $169
Nissan VQ35 4bolt main stud kit $263
Nissan L20 series 4-cylinder rod bolt kit $61
Nissan L24 Early rod bolt kit $89
Nissan L24 (Late) L26 L28, VG30E & VG30ET series rod bolt kit $89
Nissan VG30 V6 rod bolt kit $89
Nissan SR20 rod bolt kit $89
Nissan VQ35 rod bolt kit $241
Toyota 3 S GTE flywheel bolt kit $77
Toyota 4AG M10 flywheel bolt kit $46
Toyota 20/22R M11 flywheel bolt kit $46
Toyota 1.3L (4E-FE/FTE & 1.5L (5E-FE/FHE) 4cyl head bolt kit $195
Toyota 7MGTE:Supra head bolt kit $160
Toyota 22R head stud kit $222
Toyota 7MGTE:Supra head stud kit $200
Toyota 4AG 16V head stud kit $218
Toyota 3 S GTE 12pt head stud kit $218
Toyota Supra 2JZA80 head stud kit $247
Toyota 1.6L (2TC) & 1.8L (3TC) 12pt head stud kit $221
Toyota Supra undercut head stud kit $189
Toyota Supra 2JZA80 undercut head stud kit $272
Toyota 1.8L (1ZZFE) 4-cylinder head stud kit $291
Toyota 1600cc main bolt kit $69
Toyota 7MGTE Supra 2-bolt main stud kit $204
Toyota 4AG 16V main stud kit $146
Toyota 3SGTE main stud kit $150
Toyota Supra 2JZA80 main stud kit $208
Toyota 22R main stud kit $134
Toyota 4AGE, M9 rod bolt kit $79
Toyota 22R rod bolt kit $66
Toyota 2TC/3TC/2TG rod bolt kit $66
Toyota 7MGTE:Supra rod bolt kit $79
Toyota 1.8L (1ZZFE) 4cyl rod bolt kit $116
Toyota Supra 2JZA80 rod bolt kit $116
Mitsubishi 4G63 balancer bolt kit $50
Mitsubishi 4G63 head bolt kit $169
Mitsubishi 2.0L 4-cylinder 16V head stud kit $145
Mitsubishi 2.6L 12pt head stud kit $168
Mitsubishi 4G63 '94 UP M11 head stud kit $178
Mitsubishi/Dodge 6G72 DOHC ARP2000 head stud kit $545
Mitsubishi 2.0L (4B11) turbo head stud kit $244
Mitsubishi 4G63 M12 head stud kit $180
Mitsubishi 4G63 M11 head stud kit $196
Mitsubishi 2.0 4-cylinder 12pt main stud kit $102
Mitsubishi 2.6L 2-bolt main stud kit $134
Mitsubishi 2.0L (4B11) turbo main stud kit $274
Mitsubishi 6G72 3.0L 6-cylinder '93 & up main stud kit $230
Mitsubishi 2.0L (4BIIT) rod bolt kit $164
Mitsubishi 4B11T cam tower stud kit $256
Mitsubishi 4G63 Pre '94 M9 rod bolt kit $61
Mitsubishi 4G63 '94up M8 rod bolt kit $61
Mitsubishi 2.6L rod bolt kit $66
Mitsubishi 3.0L & 3.5L V6 rod bolt kit $93
Mitsubishi 4G63 Pre '94 M9 rod bolts $21
Mitsubishi 4G63 '94 & up M8 rod bolts $21
Mitsubishi 2.6L rod bolts $23
Mitsubishi 3.0L & 3.5L V6 rod bolts $23
Honda B16/B18 balancer bolt kit $50
Honda D-Series 1.5L & 1.6L SOHC flywheel bolt kit $60
Honda B-Series 1.6, 1.7, 1.8 & 2.0L DOHC flywheel bolt kit $77
Honda D16A & D16Z M10 head stud kit $177
Honda/Acura B18A1 12pt head stud kit $222
Honda/Acura B18C1 VTEC 12pt head stud kit $211
Honda H22 A4 VTEC head stud kit $236
Honda D16Y head stud kit $162
Honda B20B, with B16A head, head stud kit $211
Honda H23A, head stud kit $230
Honda B16A head stud kit $209
Honda/Acura K20A (A2 & A3) head stud kit $217
Honda F20 S2000 head stud kit $215
Honda H22A & H23A main stud kit $161
Honda B16A & VTEC main stud kit $131
Honda/Acura B18C1 main stud kit $145
Acura B18A1/B1 main stud kidt $133
Honda/Acura 1.2L & 1.6L M8 rod bolt kit $65
Honda S2000 rod bolt kit $155
Honda/Acura K20A rod bolt kit $155
Acura NSX 3.0L M9 rod bolt kit $236
Acura NSX 3.2L M8 rod bolt kit $235
Honda/Acura 1.8L M9 rod bolt kit $127
Honda SOHC pressure plate bolt kit $25
Honda DOHC pressure plate bolt kit $33
Mazda Miata head stud kit $186
Mazda '03 2.3L DOHC 16V head stud kit $224
Mazda '98-'02 2.0L FS-DE head stud kit $162
Mazda 2.5L (KLSeries) V6 head stud kit $367
Mazda Miata main stud kit $146
Mazda '03 2.3L DOHC 16V main stud kit $159
Mazda Miata '88-'05 rod bolt kit $115
Subaru EJ2.0L & 2.5L DOHC head stud kit $298
Subaru EJ Series Phase 2 '99 to present SOHC head stud kit $347
Subaru EJ2.0L & 2.5L head stud kit w/300-8374 nuts $301
Subaru EJ20/EJ25 case bolt kit $582
Subaru EJ Series press fit rod bolt kit $161
Subaru EJ25 DOHC turbo rod bolt kit $120
Courier on any item - +$8
Fortyone.co.nz
Postby MrOizo » Thu Dec 13, 2012 8:29 am
Bringing a thread back from the past!
Can I get a price for a Tial yellow spring suitable for the Q BOV please?
Churs
MrOizo
Toyspeed Legend
Postby Fortyone.co.nz » Thu Dec 13, 2012 2:40 pm
MrOizo wrote:Bringing a thread back from the past!
Churs
Yup $37 + Courier (or pick up free!) - Courier $7, or I guess NZ Post could ship it for $4!
Fortyone.co.nz
Postby MrOizo » Thu Dec 13, 2012 3:24 pm
Churs
Sounds good!
According to the pic below, i need the yellow one.
And to double check my maths, accoding to the gauge i have 65-70kPa of vacuum.
65 kilopascal = 19.248708116 inch mercury (60°F)
70 kilopascal = 20.729377971 inch mercury (60°F)
If this is the case, SOLD! :D
MrOizo
Toyspeed Legend
Postby Fortyone.co.nz » Fri Dec 14, 2012 12:26 pm
Yep that's what we went off also - the chart. Yellow is confirmed price wise.
Fortyone.co.nz
Postby MrOizo » Fri Dec 14, 2012 12:34 pm
Emailed!
Cheers :)
MrOizo
Toyspeed Legend
Return to Toyspeed Sponsors
