Motul Mo Cool - Need to reduce your engine water Temps????
Postby Bazda » Fri Sep 16, 2011 3:33 pm
Motul Mo Cool - Reduces Radiator temps up to 15 Deg C!!
- Improves thermal exchange and engine cooling system efficiency.
- Cooling system optimal protection against corrosion.
- Recommended for magnesium, cast iron, aluminium alloys cases, brass copper, and bronze systems.
- Water pump protection, avoid cavitation.
- Anti corrosion and rust properties that remain during high temperature and ageing.
- Low corrosion inhibitors consumption.
- Seals, rubber pipes, and plastic parts friendly.
Features
* Runs up to 15'C/30'F Cooler
* Suit Street, Race & Offroad Use
* Improves Heat Transfer
* Increases Performance
* Reduces Corrosion
* Compatible with Coolants
* Concentrated (Mix at 5%)
$35 incl per bottle
Return to Toyspeed Sponsors
