These are one of the most robust clutches I have come across. Never had one fail and never had one slip! Driveability is great and pedal feel is nice and soft.
So now we can offer these to all you Toyspeed members!
Tilon Twin plate & single plate clutches
All clutches supplied are the Rally Cerametallic drive units. These utilise thick 0.250” thick clutch plates which are able to be slipped and able to hold 700WHP+ on the twin applications. Single disc applications up to 350WHP
These are very popular in the USA esp for Evo drivers. Super robust units!! and not too bad for daily road use!. We have heaps of Corolla Turbo guys running these now! they all love the way they feel and grip.
- Custom kits with billet flywheels and release bearings
- Hydraulic bearings also available from $300
- Triple plate also available for the super high hp applications.
Full Bolt on Kits:
Toyota Corolla 4age/ze FWD, RWD (T50/W5x) Super light weight Single plate (rated to 350whp) $1500
- Billet 5kg flywheel
- Billet bearing cradle
- Specially designed conical bearing which makes pedal pressure very soft.
- Bolt kit
Toyota Corolla 4age/ze FWD, RWD (T50/W5x) twin plate $1800
- rated to 650hp
- Billet flywheel 5kg
- Bolt kit
http://www.mrpltd.co.nz/product/111/4ag ... wd-29.html
Toyota 1J/2J/1uzfe to W55 or R154 $1850 - Special $1800
- Optional Hydraulic bearing setup +$200
- Will have to use the Auto ring gear, can supply for extra $100.
http://www.mrpltd.co.nz/product/188/1uz ... h-w55.html
Toyota Supra Twin Turbo with Getrag 6 speed $1900
- Rated to 1000hp
- Custom billet flywheel
- Hydraulic release bearing kit
- All hardware for installation
Other models:
Mazda RX7 FC/FD
Honda (Vtec)
Nissan RBs
Mitsuibishi Evo 1-3
Mitsubishi Evo 4-8
