Hydraulic Clutch Bearing Setups W55 W57 W58 R154
Postby Bazda » Mon Jul 30, 2012 2:23 pm
Hey Guys,
We have bolt on Hydraulic bearing setups available for: W55 W57 W58 & R154 boxes (using push style clutch).
This kit gets rid of the fork setup and slave cylinder, thus giving you more room and a simplified setup.
The kit contains: Modified Quartermaster Hydraulic bearing assembly, external bleed line, clutch line, hardware.
Suit all OEM clutches and also race twinplate clutches.
$429 incl GST
Return to Toyspeed Sponsors
