This is one of the coolest little electronic gadgets we have available and it's called the Pivot Speed Meter V (Red - VL means Blue!). It measures your car speed, G-Forces, 0-400 meter time and removes your speed limiter (on certain cars). It's a cool little digital device that gives you a quick, accurate heads up without the massive price associated with other alternatives.
The best thing is the price - $199 delivered for Red, $219 delivered for Blue!
It is very simple to wire in (see Here) and you can see an application list here also (pdf). The Circle in the L/C column indicates the cars in which the speed limiter will be removed. Any questions - just ask! Basically it fits new OBD2 cars but I will confirm it for you. Whilst we normally have these in stock, the next shipment isn't due for ~2 weeks (red only at this stage, but no problem to order more of either color) so if you want one, get in now.
Mac
mac@fortyone.co.nz
Fortyone Automotive Limited
