MRP Coilovers - Special Price Stock clearance $1099!!!
Postby Bazda » Thu Nov 08, 2012 10:11 am
We are having a stock clearance on MRP coilovers
$1099 inc GST
Clearance only on the following coilovers-
Sentra Pulsar B14 N15
Pulsar N14/B13
Evo 1-3
Evo 4-6
RX7 FD3S
RX7 FC
Subaru GC8
Starlet GT/Glanza EP70/82/91
Unfortunately it does not include any Corolla/MR2 sets.
We have been designing & custom making coilovers since 2006 for race & street cars.
Sold hundreds across NZ/Aus. Not one to date has failed in any way!
All customers very amazed with the handling & performance.
We even provide a Shock Dyno - No other company in NZ supplies these! who knows how they are making their coilovers.
Exceptional Quality! just check out the pictures & Backed up with real life performance testing
Features:
Full height adjustable via strut length
Pillow ball mounts with Japanese made bearings Front & Rear
Aluminium camber plates (Front only)
Mono tube 12 way adjustable shock absorber
Extra strong steel powder coated lower mounts
Fine threaded Teflon coated bodies to reduce locking nuts from coming loose & corrosion
1 piece designed spring perch for easy pre load adjustment
Specially designed non slip C spanners
IP Synthetic shock oil
Double O-ring seals
46mm internal piston
All factory brackets for brake lines & anti roll bar mount points
Robust damper adjustment knobs - Spring loaded to give the user accurate feedback of clicks
All shocks are dated at time of manufacture and security sealed
Postby ke_25 » Tue Nov 27, 2012 11:27 pm
IS250?!
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby Bazda » Wed Nov 28, 2012 8:31 am
ke_25 wrote:IS250?!
Can do them in the fortune autos from usa.
Postby Bazda » Thu Feb 21, 2013 1:31 pm
TTT
Coilover options for Sw20
Postby Grrrrrrr! » Thu Feb 21, 2013 1:38 pm
pretty much as above, what options are available, and how muchy? :)
Will be a few months before i buy, but it'd be good to know how much coin I need to put aside.
Grrrrrrr!
Re: Coilover options for Sw20
Postby Bazda » Thu Feb 21, 2013 1:49 pm
Grrrrrrr! wrote:pretty much as above, what options are available, and how muchy? :)
As the first post only these models are available until stocks last.
Pulsar N14/B13
Evo 1-3
Evo 4-6
RX7 FD3S
RX7 FC
Subaru GC8
Postby flying_wedge » Thu Feb 21, 2013 2:37 pm
Pity no MR2 on special. Would be keen to upgrade from BC coils. Do the rears have camber adjustable top hats?
flying_wedge
Postby Bazda » Thu Feb 21, 2013 2:40 pm
flying_wedge wrote:Pity no MR2 on special. Would be keen to upgrade from BC coils. Do the rears have camber adjustable top hats?
Send me a PM will see what i can do for you regarding price.
We can install camber adjustment rears for a small additional cost.
Return to Toyspeed Sponsors
