Dry sump kit 4age/7age Group Buy
Postby Bazda » Sun Jan 13, 2013 9:49 am
Hey Guys,
So we will be putting together a dry sump kit to suit all 4age/7age engines.
FWD or RWD, we can place the pump any location you want!
The kits wont be ready until March ish.
The kit will contain the following:
- 3 Stage custom made dry sump pump (We have a few manufactures in mind at present from USA & UK)
- Pump bracket
- Drive pulleys and belts (bolts to the crank pulley)
- Custom Moroso sump with -12AN ports
- 2 Gallon Peterson aluminium tank with brackets
- 2x -12AN Moroso Screen filters
- Moroso breather Can
- Moroso oil filter block off plate
- Moroso adjustable vacuum relief valve
- Vacuum gauge
Price is going to be around $3200NZD mark. Maybe even cheaper depends on how many parts we order.
Deposits can be made here:
http://www.mrpltd.co.nz/product/305/4ag ... p-kit.html
AN fittings & braided line is extra cost. But we can get fittings at good prices (Around $30NZD a fitting)
Return to Toyspeed Sponsors
