MRP 4age Turbo Exhaust Manifolds - FWD & RWD
Postby Bazda » Thu May 30, 2013 3:29 pm
Hey Guys,
As usual we are always making custom 4age items!
Both FWD (Suit all AE chassis) & RWD (AE86/KE70/ plus other RWD engine bays)
Also 7afte is now available
http://www.mrpltd.co.nz/browse/118_255/ ... folds.html
$740 incl
That gets you a single entry manifold not coated with wastegate port. Divided setups are an extra $150NZD
Coatings are extra on top.
Flange suits both 16v/20v heads
Equal length runners
Ram Horm Style to maximise runner length
Long low angle merge collector to maximise flow into turbo
Material - 3.7mm Steam Tube SC40
Coatings - Optional Ceramic (700C) or Black Satin (1000C)
Turbo Flange - All flange types available please specify on cart check out (T25/T3/T4/T3 Divided/T4 Divided/TD05 etc)
Fully TIG welded
12mm Thick Flanges
M10 studs & nuts provided
Optional wastegate port to suit 38mm 2 bolt Tial style - Must supply wastegate flanges if another type
Divided Flange Setups:
When using a twin scroll ex housing setup the runners are placed in the correct firing order to maximise the pulsing of the cylinders. This system is more complex to build which requires either 2x wastegate ports or a 2-1 wastegate setup.
2 Model types available for FWD:
Non Air Con setup - Turbo compressor housing faces cam belt side of engine meaning shorter IC piping can be done.
Air Con setup - Turbo compressor housing faces gearbox side.
Both models fit with Power Steering
1 Model Types for RWD - Top Mount, compressor angled facing towards head light.
All Manifolds come with a 10 year no crack warranty
If the model you choose is not in stock there is a 1-2 week lead time.
We can custom make to suit your requirements as well.
Postby mint_86 » Thu May 30, 2013 11:26 pm
Any chance of a stainless catback ae86 exhaust making its way into the MRP catalogue?
Cheers,
Clifton
mint_86
Postby Bazda » Fri May 31, 2013 8:43 am
mint_86 wrote:Any chance of a stainless catback ae86 exhaust making its way into the MRP catalogue?
Cheers,
Clifton
Not at this stage
Postby Vertigo » Sat Jun 01, 2013 8:25 pm
That FWD manifold looks super cool. I assume it fits in AW11's also?
TVIS just kicked in, yo!
Vertigo
Postby Bazda » Sat Jun 01, 2013 9:33 pm
Vertigo wrote:That FWD manifold looks super cool. I assume it fits in AW11's also?
No the AW11 needs a flatter style. I think it would hit the hood body of the car.
Postby Bazda » Mon Sep 23, 2013 8:42 pm
Taking orders for RWD versions.
We are working on the FWD ones, and need to find someone to test fit into an AW11
Re: MRP 4age Turbo Exhaust Manifolds - FWD & RWD
Postby Bazda » Thu Mar 13, 2014 11:32 am
Bump, 7afte is now available
Return to Toyspeed Sponsors
