event2 wrote:check you earths onto your battery we had a car at work that the tacho needle would go up and down and lights on dash would go on and off randomly and it had a seperate earth wire for dash that was lose and stuffing evey thing up. so u might not of needed a new abs sensor. i cant rember wat type of car it was but year. when the earth goes off power from another dash light might b back feeding into the abs light and it will cum on and the tacho needle will go down because it will b on the same power feed. hope this helps
caldywrote:hi nemesis,
sorry no answer to your question but can you please run through the steps you took to replaceing the sensor, from what ive tried theyre a biatch to get out without breakin them... what did you do?
cheers mate.
MartinNZ wrote:How many wires on the sensor and what are their functions? If its 3/4 wire its possible the sensor or wiring loom has an intermittant short circuit which could pull down one of the supply rails inside the ECU or put it into limp mode?
Cut it open and have a look?
Martin.
