ae85 -> 20v fueling
ae85 -> 20v fueling
Postby spencer » Wed May 12, 2004 10:44 am
hey just wondering if its gunna be easier to use ae86 fuel pump with my 20v? does it bolt in or need the whole 86 tank? Or do I use origy pump into a surge tank then onto high pressure fuel pump, I already have a VL fuel pump sitting at home. Also with fuel lines should I find ae86 one or bend one up, I bent one up for my ke70 but was a mish.
ms63 crown
spencer
Postby Drifter4ag » Wed May 12, 2004 1:01 pm
if you can find ae86 tank + pump the lines already on the car should all bolt up. ae86 pump is more than enough for a 20v .. but for ease run a low pressure pump from your fuel tank into a surge tank then high pressure VL or similar into fuel rail.. its pretty easy
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
