ae101 levin question #1 dash board removal
Postby strap-on » Sat May 08, 2004 6:48 pm
neone done this? or know any tricks or something to get it off? im hopeing if i pull it out i can find a spot somewhere to get some stuff thru the firewall.
strap-on
Postby Ae92typeX » Sat May 08, 2004 7:36 pm
What are ya putting through the firewall?- would it fit through the arch grommet where the main loom goes?- just it'd be a lot less work to do it that way if it does.
Ae92typeX
Postby strap-on » Sat May 08, 2004 10:33 pm
its a hose for a vaccum gauge, and is that the arch on the passenger side u mean? cos the hose wont strecth all the way over that way, i should get a longer one, but meh
strap-on
Postby neo » Sat May 08, 2004 11:55 pm
just be a horey bastard and bung it through with the accelerator cable or the like... thats easy to find..
removing a dashboard without removing the windowscreen is a mission and a half
neo
Postby Silvertop » Tue May 11, 2004 12:26 pm
If you do decide to be a crazy cookie and remove the dash, you can have a look at the new dash I have sitting in the garage for the clip location... or I could take a pic for you...
Silvertop
Postby Silent Knight » Tue May 11, 2004 1:03 pm
removing a dash for a 101 is easy ass.....i've done it heaps of times before :D :D :D
Silent Knight
Postby AceSniper » Tue May 11, 2004 1:33 pm
just find the gromit behinde the quads that the heater cable runs through, slit the gromit abit and feed the tube through... itll come out up around the top of your clutch peddle. :wink:
AceSniper
Postby rollas22 » Tue May 11, 2004 2:40 pm
Ive removed the dash in my ae101, took 45mins pieace of piss. but for just a vacum gauge i wouldnt bother find the hole that is pritty much next to the clutch peddle. i only pulled mine out to get it all redone in white leather look. just becarefull when pulling it out as the whole wiring system is attached to the dash itself, along with a few other plugs.
rollas22
Postby strap-on » Wed May 12, 2004 7:15 pm
so ne advice on how to remove?
strap-on
Postby ELiTeHaYDeN » Sat May 15, 2004 12:11 pm
dont.
you want to remove it JUST to get a vaccume gauge pipe through? go through one of the exisiting holes in the firewall you just push it in from the engine bay and then find in under the dash :P - most cars have plenty of holes for such things.
ELiTeHaYDeN
Postby strap-on » Sat May 15, 2004 12:25 pm
ELiTeHaYDeN wrote:dont.
u dont know much about the 20v's then do u?
na i found the grommet someone was on a about, i just had to take off my plenum chamber to get to it
strap-on
Postby AceSniper » Mon May 17, 2004 12:15 am
I agree...
if its the gromit that has a black cable going into it... you should have no problem feeding the tube through with the plenum chamber on, just slit it abit tape the vacume tube to the end of some stiff wire and feed it through... just pull the wire on the other side and drag ya tube through, just make sure u dont squish it with cable ties or let it cut on a sharp edge, also be sure to get the right vacume line... my first attempt i ended up with a bouncing needle reading just one cylinder heh :oops:
AceSniper
Postby strap-on » Tue May 18, 2004 9:35 am
dude, im not completly mornic, it was just as far as i was aware i couldnt see asny places to get thru th fire wall, the fact that i have already told ppl that i have got the hose thru and they are still telling me how to get it thru says alot bout thsi forums,
i wanna know how to get the dash off for shits and giggles
and lol i also wanna know which hose u hooked ur vacuum gauge up to
strap-on
Postby AceSniper » Tue May 18, 2004 3:47 pm
yea sorry :P
the hose I hooked up to make it work? or the other one? first one I got was a idle vac or sumthen I think. ill have to get a digi foto to be able to explane, dosnt seam to take much foot to push the needle to the stopper... (0 vac) think its sumthen todo with the quads
I undone my dash enuff to slide it away from the windscreen once was just bolts in the telltail hiding spots but i couldnt pull it much further with out undoing wiring (I think)
AceSniper
Postby strap-on » Tue May 18, 2004 4:38 pm
so where is it hooked up 2 now?
strap-on
Postby AceSniper » Wed May 19, 2004 2:00 pm
AceSniper
Postby strap-on » Thu May 20, 2004 10:27 pm
pic didnt work
strap-on
Postby PumpN » Thu May 20, 2004 10:36 pm
copy paste the link, angel fire doesn't like being linked to forums
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
