small blocks in toyotas
Postby jimbolompoc » Mon May 17, 2004 1:28 pm
Will a chevy small block V8 fit in my tacoma's engine compartment? :wink:
jimbolompoc
Postby Mr Revhead » Mon May 17, 2004 3:15 pm
buy a tape measure and find out. but i think it will
Postby 92GTApex » Mon May 17, 2004 4:08 pm
It should fit being quite a compact engine,
But the question is why?
When a 1UZFe is a far superior engine
Have a look at www.lextreme.com for more information and ideas
(Im guessing that you are in the states when you mention the Tacoma)
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby [V8ROLA] » Thu May 20, 2004 8:15 pm
how can you say a motor that pulls on average of 250+hp bad???
i have a small block chevy in a series 2 RX7 and its pulling round the 350hp mark and they dont actually weigh that much and im not knocking the 1UZ cause i also have a 1UZ twin turbo in a toyota corolla 2 (major mods to fire wall etc)
as for ease of fitting the SBC will fit pretty much any engine bay out there, the 1UZ is 600 square and you have to remember with the 1UZ you have all the wiring, computer etc to wire up where as with a SBC its pretty much straight forward. fuel lines are there and are big enough and the wiring should just wire up to the motor.
there is a toyota corolla DX sedan here in wellington that has a 350 in it and it is dam quick with 500hp :?
Engine Displacement A B C D E SUMP STARTER
Chevy Small Block A26.50" B27.00" C20.50" C26.00" D27.00" rear right
A being total lentgh from bellhousing to front of water pump snout, D being the total width from the edge of valve cover to valve cover.
personally i would go SBC for ease of apllication and they can get an easy 500hp+ N/A with stuff all major mods and parts are so readily available its not funny.
being the owner of both motors i preffer the chevy over 1UZ.
theres my 2 cents worth (well 4 cents with that much :P)
1995 ducati 900ss with a 2001 fuel injected motor, ramflow intake, open pipes, polished wheels and afew other mods.
more to come ;)
1983 RX7 series 2 with small block chevy.
http://photos.data.net.nz/?dir=V6ROLA%2 ... sion%20%2F
[V8ROLA]
Real Life Mechanic
Postby 92GTApex » Fri May 21, 2004 2:46 pm
I was lead to believe that the 1UZ was closer to 700mm?
But still quite alot bigger than the SB Chev
Correct me if im wrong
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Postby FLAWLES » Fri May 21, 2004 6:42 pm
hey all i can say to this is
YES THEY DO we done it to a ke35 sr coupe a little while back cant remember what box we use but it did fit
FLAWLES
Postby wde_bdy » Sat May 22, 2004 1:24 am
[V6ROLA] wrote:how can you say a motor that pulls on average of 250+hp bad???
Never seen anyone make an "easy" 500hp from a small block. Don't believe all the numbers people spout off.
Having said that, at least with the small block you don't have to piss around with all the excess wiring and given were talking about a Tacoma it means "I am in the US" so the small block will be a much cheaper proposition with parts on every street corner.
Callum
wde_bdy
Postby FLAWLES » Sat May 22, 2004 10:52 am
true in the states engine parts for old push rod v8s are every were and a cheap hell they hve nearly been around for about 80+ years
ok
i want to start another q here why a chev y not a nice 302 clevland or winsdor if you ask me they sound better rev better and u can get more usile hp out of them
FLAWLES
Postby Mr Revhead » Sat May 22, 2004 12:32 pm
why not a 4cam from a mustang.... mmmmmmmmmmm
and and interesting fact... what engine in the ENTIRE world has the most performance parts sold for it.... NOT the sbc but the ford 302 windsor
Postby FLAWLES » Sat May 22, 2004 12:53 pm
or hey the boss 290 " basicly the same engine as a mustang quad cam "
but yes thank you for that nice peace of ford info
GOE THE FORDS
oh and the TOYOTAS
FLAWLES
