Can someone explain boost control to me
Postby Volatile » Sun May 30, 2004 2:51 pm
say if you were turboing a originally standard NA motor how do you control what level of boost you get?
is it just a matter of choosing the appropriate actuator?
just asking becuase i only want to run 4-5psi and not many factory standard boost cars run as low as that?
James
Volatile
Postby Malcolm » Sun May 30, 2004 3:19 pm
Yes, it is all about the actuator. If you want to go as low as 4 or 5 psi then you may struggle to do so. If you can find an actuator that opens at such a low pressure, chances are that it wont fit your turbo and will need a new bracket and possibly changes to the rod length + fitting.
Postby Volatile » Sun May 30, 2004 5:45 pm
oh k :? bugger
how do people who have turbo'd blue tops go about keeping the boost at 4-5psi so that it can be run with no cooler,std ecu, standard injectors. just as a starting setup
Volatile
Postby turbo tezza » Sun May 30, 2004 8:43 pm
My turbo has an adjustable waste gate actuator. You can adjust the length of the rod for the actuator. I think its an HKS product ( my car came with it) or GReddy/Trust.
When i got my car, it was only running 3 psi, so it can be done.
Corey
turbo tezza
Postby TWSTD » Mon May 31, 2004 11:47 am
contact Brendan (nite parts) - he will help u out. I think he is "nite-b" or something on this forum. They make turbo kits for 4ages....
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
