Reccommended injectors for lumpy cam bluetop 4age
Postby ChaosAD » Sun May 30, 2004 7:05 pm
What sort of injectors do you guys reccommend for a mildly worked bluetop running a megasquirt and a set of 240/232 degree (at .050" lift) 8.8mm rally cams?
Would a set of redtop injectors do the trick? or are they still a bit small?
There was an article on working 4age's in 'ZOOM' magazine a while ago that reccommended a set but I cant remember what they were.
What voltage are the injectors supposed to run at?
If I use redtop injectors should I also run the injector resistor box?
Also, what sort of fuel pump do you guys reccommend? or is the stock pump fine?
ChaosAD
Postby bridgeport » Sun May 30, 2004 11:01 pm
stock pump should be ok and id try get the red top ones there good aparently cause i had a guy come out and look at some i was selling for his worked 4age but they turned out to be red top tvis ones which are the same as blue top just different plugs
or gze ones (?)
bridgeport
Postby Mr Revhead » Mon May 31, 2004 10:49 am
i got a set of non tvis redtops ones incl fuel rail that maybe for sale..... make an offer :D
Postby ChaosAD » Mon May 31, 2004 7:07 pm
I dont need the fuel rail as the redtop fuel rail is a different spacing to the bluetop one.
What sort of ballpark figure are you looking at for the injectors as there is another guy on this forum that is taking offers.
ChaosAD
