can someone tell me the differences between the blue top tvis 4age and the red/black top tvis 4age? and are the ECU's and loom's compatible?
churs
gdsup wrote:red/black top have better crank and heavier block, looms and ecu's are not entirely interchangable, ie use must use 1 or the other full system, they run different injectors sizes and ignitors etc, the ecu badidass is talking bout is type 61, last 2 digits on the label, and is bluetop system
Mr Revhead wrote:redtop non tvis injectors have different plugs and are apparantly higher flow.
Users browsing this forum: Google [Bot] and 33 guests
