AE101 problems
AE101 problems
Postby Dodgy Guy » Sat Jul 10, 2004 4:39 pm
Hey all, ive had my 92 fxgt for a while now (like 8 weeks) and noticed a few things....
(1) when acclerating i find that she's good til about 3000 - 4500 rpm. with in that range theres a HUGE flat spot. any ideas?
and
(2) Compared to my 1988 fxgt, my 92 fx is not as perky. what can be done / who should i see?
Dodge :twisted:
Dodgy Guy
Postby Chickenman » Sat Jul 10, 2004 7:09 pm
Sometimes you buy a car... and it's poked. If you've done all the routine maintenance stuff (plugs, leads etc) and you're still not getting what you want, go to a mechanic and get a compression test etc. The toyota dohcs in the g heads are made to be revved higher, with a (slight) decrease in lowend performance. If you had an old f head engine you would have noticed a little more lowend torque. Dunno :?
I definately recommend using the search function on the forum, heaps of stuff bin written about refreshing tired engines/basic performance mods etc.
Baby Jesus
Chickenman
I Am The Walrus!
re flatspot
Postby shaggz » Wed Jul 21, 2004 1:42 pm
hey i had a levin with the same motor mine did the same till i put in a pod filter and cleaned up the leads and made sure the sparkplugs were nice and clean its around that time that the car changes its valve timing and starts producing power check to make sure nothigns sticking in the throttle body area as well
shaggz
