Turboing a redtop?
Turboing a redtop?
Postby wannabe86 » Thu Jun 10, 2004 5:48 pm
we got turbo, intercooler, manifold etc. only want to run 6psi, on ae86.
do we need to lower compression? How is this done? head gasket?
how do we get extra fuel to the engine?
what MAP sensor is best to use?
shoul we use any particular spark plugs?
any info is appreciated.
wannabe86
Postby SIDE_FX » Thu Jun 10, 2004 11:53 pm
if u doin 6psi just give the engine a rebuild no need to decompres for such small boost just use the red top ecu nd map andd talk to fatke30 he will telll u how to trick the map and some othr little tricks ah + he will make u a manifold if u need it
SIDE_FX
Postby EVLGTZ » Fri Jun 11, 2004 5:20 pm
I wouldnt even waste my time with a rebuild unless the engine was totally poked. Just go for it 8)
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Bazda » Fri Jun 11, 2004 6:32 pm
maybe still need extra injector?
Postby FLAWLES » Fri Jun 11, 2004 6:54 pm
nsah i ive seen a ae86 with a standard red top witha ca18 turbo just runing 6psi didnt de compress or add a extra injector
went nuts
he he might be my next car
FLAWLES
Postby Bazda » Fri Jun 11, 2004 7:40 pm
prob knock the timing back a fair bit when going turbo.
Postby CHOMPA » Mon Aug 02, 2004 5:55 pm
You use a decompression plate john bro,
Running a t25 ca18det turbo or sr20... Good drifting set-up like andrews has turbo lag you need boost in lower revrange dto drift good.
CHOMPA
Postby Drifter4ag » Mon Aug 02, 2004 8:45 pm
um .. you dont need anything in lower rev range to drift good. You just need to be able to drive a car semi good.
4age engine is high rpm power engine anyway so your down low power is always going to be shit.
Decompression plates have a tendancy to blow through cylinders.
Redtop turbo makes massive power with any turbine.
Dont decompress it for anything under 10psi
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby gdsup » Mon Aug 02, 2004 11:40 pm
just make sure you fuel it right, some sort of extra injector controller like link etc
gdsup
Postby MetalupYoAss » Tue Aug 03, 2004 10:27 pm
drifter 4ag; have you run up to 14psi on a stock bluetop (wit heaps of fuel) and used standard compression? is it a reliable setup?
MetalupYoAss
Postby Drifter4ag » Wed Aug 04, 2004 11:13 am
yes i have
its plenty reliable long as your timing is well sorted as well. And you are running a good intercooler .. but any car running 1bar should be using a good intercooler. and as my signature states 1bar on the turbo i was using = 176kw@wheels bo.
But of course it will shorten its life somewhat but nothing for you to cry over if you can do an engine swap every 8months or so .. boohooo ..i blew up my $40 engine boo hoo :P
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby MetalupYoAss » Wed Aug 04, 2004 5:59 pm
sweet then ive got like 2 years of spare motors
MetalupYoAss
Postby AE85.6 » Thu Aug 05, 2004 4:06 pm
sssssh stop speaking of such things otherwise i may have to look into it after gearbox etc is sorted, oh and lsd too
If you drink, and drift,
your a bloody lunatic
AE85.6
