Oil press. sender units same on both big port 4ag??
Postby TotemoAW11 » Sat Aug 28, 2004 2:41 pm
I have an 89' AW11 with 7rib red/black top 4age, the factory oil press. gauge doesnt work, so i wanna replace the sender unit.
I can get one for a blue top, will it fit and be accurate as a straight replacement?
I assume it will but just checking to be sure :wink:
TotemoAW11
Postby ChaosAD » Sat Aug 28, 2004 6:15 pm
Depends, my bluetop used an oil pressure light instead of a gauge. Because of this it has a different type of sensor.
Probably better off buying a new one, they dont cost that much.
ChaosAD
Postby TotemoAW11 » Sat Aug 28, 2004 7:16 pm
problem sloved
the gauge on the right is an oil pressure one i found lying around, air vents are over-rated anyway :wink: and now i have a swiveling gauge :mrgreen:
Anyone who knows whether the sensors would have been the same feel free to answer incase someone else wants to know later on and knows how to use the search :)
TotemoAW11
