compression for 4agze
Postby gtz666 » Mon Sep 06, 2004 6:16 pm
hey does anyone know what the compression should be for a afm 4agze in psi when doing a compression test or where i could find out
ps searched for this but only came up with the compression rato of 8.0:1 which is not the figures i'm after :)
gtz666
Postby kingcorolla » Mon Sep 06, 2004 6:24 pm
your after compression pressure.
i cant help you with the gze pressure, but the comp pressure for 9.4:1 is about 11.bar
your gze would be a little less due to lower comp ratio
hope this helps!!
1983 Carina AA63 4age
kingcorolla
Postby Lloyd » Mon Sep 06, 2004 6:43 pm
Just check to see if they are all about the same. I think when I did my 2nd gen 4AGZE it was about 170 all round
Postby FLAWLES » Mon Sep 06, 2004 6:44 pm
depending on what ze engine you have az there are two diff type of compression ratios on psi readings
what car is it out of a ae101, ae92 or a aw11??
FLAWLES
Postby gtz666 » Mon Sep 06, 2004 7:07 pm
it is an ae92 air flow metered version
gtz666
Users browsing this forum: Google [Bot] and 20 guests
