buddy club racing spec suspension
Postby clutch_cargo » Wed Sep 08, 2004 6:33 pm
hi i just bought an ae111 bzr levin, the car runs great but the settings for the suspension is too hard at the rear, the current suspension set up are Koni yellows inserts on the front which are set to firm (no probs here) and buddy club racing spec dampers with a 5k coilover setup which are set to hard (car prolly ran circuit in japan)
the ride at the back is very twichy and the car jumps at the slightest bumps, it is very dangerous to drive this car at high speed on unleveled roads.
what i would like to know is how do i adjust buddy club racing spec dampers as to soften the dampening at the rear?
thanks in advance
clutch_cargo
Postby Wind Rider » Sat Sep 11, 2004 11:03 am
if it's damping adjustable, at the top there would be a pin sitting on a rectangular nut, put an adjustable spanner on the rec nut and adjust the pin with a set of pliers.
Wind Rider
