ae92 Instrument cluster
Postby redline racer » Wed Sep 29, 2004 1:34 pm
Hey, I need to take the instrument cluster out of my ae92 fxgt to replace a couple of blown bulbs, I have got it undone but cannot get it out far enough to acess the bulbs, it seems to be caught because of the speedo cable? What is the easiest way to remove it? Any help would be appreciated.
Cheers.
redline racer
Postby aesc » Wed Sep 29, 2004 1:36 pm
If its anything like an ae101 cluster, there will be wiring looms clipped into the back of it. Carefully pull the clips out of the back of it and it will come free
EX AE101 owner
2013 Ford Focus ST
aesc
Postby darkman0101 » Wed Sep 29, 2004 1:53 pm
From memory the way I did it was to unscrew the speedo cable coupling in the engine bay.
It should by in the middle between the engine and the firewall.
Just unscrew it and it should give you enough slack to unclip the cample from the back of the cluster.
Jas
darkman0101
Postby redline racer » Thu Sep 30, 2004 1:32 pm
Cheers guys, Done! :D
redline racer
Users browsing this forum: Bing [Bot] and 30 guests
