3Au into a RWD starlet?
Postby nath » Wed Oct 06, 2004 10:44 pm
I was thinking of putting a 3au into a RWD starlet and was just wondering whether the sprinter cross member will bolt straight in? and any other hints or advice
nath
Postby wde_bdy » Wed Oct 06, 2004 10:51 pm
Sprinter crossmember won't go anywhere near fitting, and the 3A is simply not worth the effort and cost. At least go to the 4A-GE if you are going to do an engine swap.
Callum
wde_bdy
Re: 3Au into a RWD starlet?
Postby matt dunn » Wed Oct 06, 2004 11:26 pm
nath wrote:I was thinking of putting a 3au into a RWD starlet and was just wondering whether the sprinter cross member will bolt straight in? and any other hints or advice
For the money you will spend buy a 5k and fit it straight in. easier and as good as a 3A. ( no-where near as good as a DOHC though )
