AT141 Corona GT 4AGE Q's!
Postby Tofu » Thu Oct 28, 2004 10:43 pm
just some questions as i have just bought one ;)
1. Do the AE86 share the same rails? (so i could use the 86 seats) if not what cars do?
2. Will the TRD spec race springs off an AE86 fit on the AT141 struts?
3. are the TA63's interchangable with front and rear bumpers and headlights?
4. what parts can be interchanged from different chassis? (i've been told that they are basically a 4 door 86 so 99% of stuff will fit)
any help and other info would be great.....
[WAAA] - 98' JZX100 Chaser Tourer V
Tofu
Postby wde_bdy » Thu Oct 28, 2004 10:50 pm
The AT141 is MUCH closer to a TA61/63 in floorpan than it is to an AE86. The 86 is very closely related to the KE70.
Callum
wde_bdy
Postby gdsup » Thu Oct 28, 2004 11:20 pm
i had some ae86 trd rear springs in the back of my cressida which use f series independent rear same as ta63, if the platforms are the same diameter i wouldnt reconmend it, best bet is to measure the spring diameter when you recieve the car
gdsup
