4K Carb Changing
Postby kingcorolla » Sat Nov 06, 2004 2:30 pm
the accel cable should be on the other side of that pic, and that side looks like an auto choke system.. u sure it needs a choke cable? if so it should be on the same side as the acc linkage. what engine is that off? 1S? 3T?
not sure which spring is hanging loose.. :?
did someone else remove the carb?
1983 Carina AA63 4age
kingcorolla
Postby fangsport » Sun Nov 07, 2004 9:37 am
has someone removed the auto-choke and set p a manual one. the side facing in the picture looks like the mounting point for a choke cable.
fangsport
