AE92 jurks on light throttle(still doing it after setup TPS)
Postby Lloyd » Tue Nov 30, 2004 7:50 am
Mine was jerking on light throttle also, forgot I'd put a different TPS in it and hadn't set it up right.
Yellow = Vcc
Red = VTA
Blue = IDL
Brown = Earth (E2)
Once you've got the 2 middle setting right it should be fine.
Postby BL8KK9T » Sun Dec 05, 2004 5:06 pm
nah bro minie does it just reving about 2000rpm, you can hear something clicking then the rev drops stright after(stop injecting apparently) and kick back in stright after...
yes officer, our sober driver is right behind us
BL8KK9T
Postby THA SHZ » Wed Dec 15, 2004 10:08 pm
Maybe u have ur vaccum hoses round the wrong way ? :?
THA SHZ
Postby Lloyd » Wed Dec 15, 2004 10:14 pm
Dont suppose you've checked the ECU for codes?
Postby BL8KK9T » Wed Dec 15, 2004 10:21 pm
yep check the ecu no code! dont think i got the vacuum hoses rund the wrong way.....theres only like 5 of them,,, and yeh the i got the auto electrication to check the tps,,,,
anyway vacuum hoses, theres 2 on the throttle body facing left(dont know what they for) and 3 coming out of the intake 1 block up one goes to MAP one goes to fuel reg. and one to vacuum booster?? any of those sounds wrong?
BL8KK9T
Postby BL8KK9T » Wed Dec 15, 2004 10:23 pm
anyway, its using the tvis loom and ecu to run the small port,,, can that cause any problems??
BL8KK9T
