can someone sort my timing...please
Postby ris4ray » Wed Dec 15, 2004 9:27 pm
its an 84 corolla with a 4a engine
will i dont know whats causing it but it is the timing thats suffering
ris4ray
Postby kingcorolla » Wed Dec 15, 2004 10:40 pm
yep its points ignition.
check the contact breaker gap, inside the distributor,
check the dizzy rotater mount tightness, check for any play etc.
also turn the engine over with the dizzy cap off, and check for any arcing. If there is, replace the condensor.
whats the overall condition of your dizzy?
these are the things you should be checking, IF its timing thats your problem.
My bets on the contact breaker gap :)
1983 Carina AA63 4age
kingcorolla
Users browsing this forum: No registered users and 33 guests
