4AGE Idle surging
4AGE Idle surging
Postby Dragger_Dan » Wed Dec 22, 2004 8:48 am
A problem I have heard is fairly common... A bluetop 4AGE suging at idle. The engine runs fine everywhere else, no problems while revving, just surges at idle. When in drive (auto AW11) it does not surge with no revs on. Anybody had this before? What is the first place to look? Have replaced most of the vacuum lines to no avail. Any help would be great.
Dragger_Dan
Postby pc » Wed Dec 22, 2004 8:55 am
I've had this before and it was in 2 cars that had water (coolant) problems. i.e blocked radiator and leaking pipes etc. I think it is something to do with a temperature sensor getting erratic readings from cold and then hot water... but this has just been my guess. once the coolent problems were sorted the cars idled properly.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Dragger_Dan » Wed Dec 22, 2004 9:11 am
Thanks dude, I will have a look at that. I did replace a decayed bottom hose on the car, so I may need to bleed the system again. Any other suggestions?
Dragger_Dan
Postby 85AW20v » Wed Dec 22, 2004 9:47 am
Take the throttle body off and clean it all out. They clog up a bit and the bypass doesn't work correctly. Make sure the 2 small coolant lines are clear as well. Quite often it is air in the system that causes the erratic idle as well. If you can, when bleeding the system, jack the back of the car up to make sure all the air comes to one of the 3 bleed points. There's one on the left side of the radiator, one where the heater pipes come through the firewall and the last one on the thermostat housing above the gearbox.
See ya
Simon
85 MR2 20v
85AW20v
Postby Stealer Of Souls » Wed Dec 22, 2004 9:57 am
In my one the cold compensation bit of the throttle body had died... still dead to this day. Getting another one soon.
Problem being, the throttle bodies are sealed, you can replace just that bit...
That was my problem.
'86 AE85.5 Levin
Stealer Of Souls
