Aftermarket ECU for a NA 20V
Postby RedMist » Mon Jan 03, 2005 7:55 am
113kw is 151hp, unless you have unusually small horsies :D
Thats a very good effort for just cams. Someone knows what they are doing. Do you have the cam specs?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Al » Mon Jan 03, 2005 11:31 am
Im pretty sure he means 175 engine hp :)
Al
Postby RedMist » Mon Jan 03, 2005 6:02 pm
Good point.
RedMist
Postby 4AGE 8U » Mon Jan 03, 2005 7:25 pm
oops thanx for the correction al, i mean 113kw @ wheels = 151hp = in theory with 15% drivetrain loss is about 175hp @ flywheel :oops:, redmist, it's a pair of toda spec a cams i think the specs are something like 272 degree with 9mm lift
4AGE 8U
Postby CozmoNz » Mon Jan 03, 2005 7:30 pm
4AGE 8U wrote:oops thanx for the correction al, i mean 113kw @ wheels = 151hp = in theory with 15% drivetrain loss is about 175hp @ flywheel :oops:, redmist, it's a pair of toda spec a cams i think the specs are something like 272 degree with 9mm lift
113kw @ the wheels is better than the average 95-100kw that the average 20v pushes out.
so what would toda 304 duration cams do ^_^ mwahahah, have YOU got overlap?
Rayne For President!
CozmoNz
Postby 4AGE 8U » Mon Jan 03, 2005 7:57 pm
well according to al, the last time i rolled up at his house he said that my car sounded more like a 12a bridgeport than a 20v
4AGE 8U
Postby Snoozin » Mon Jan 03, 2005 7:59 pm
It does sound so tastily angry I must admit!!!
Snoozin
Postby RedMist » Mon Jan 03, 2005 8:15 pm
Bugger, the Bunderson is embarrasing. 304 degree cams, and it just purrs at 500-700 rpm... Damn you Brett from Columbus Car Clinic... YOUR TOO GOOD!
RedMist
