GZE Vacuum Hoses
GZE Vacuum Hoses
Postby CAMB01 » Mon Jan 17, 2005 8:06 pm
Does anybody have a or know where i can find a diagram for the Vacuum hoses on an AE101 4AGZE, its sort of a nightmare at this stage.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Bazda » Mon Jan 17, 2005 8:35 pm
search for a mr2 site, i found one ages ago with the diagrams.
Postby CAMB01 » Tue Jan 18, 2005 7:15 pm
cheers i've already got a diagram, but what i'm really after is something in a lot more detail like actual pics.
CAMB01
Postby evil_si » Tue Jan 18, 2005 8:22 pm
what you actually want to know?
you can get rid of most of them and still run the factory ecu just fine.
all it needs is the vacuum line to map sensor and one to fuel pressure regulator.
evil_si
Postby matt dunn » Tue Jan 18, 2005 10:17 pm
The VSV in the line to the Fuel press reg is for hot start enrichment.
The other VSV vents the supercharger bearings to prevent the grease being sucked out of them.
Matt
