Go faster mods?
Go faster mods?
Postby bigfut » Sun Feb 20, 2005 9:45 am
Just bought a new Hiace, and wanted some thoughts on things to make it go faster, I realise its a diesel and its never going to be quick, but just after some ideas to give it a bit more pace. Cheers
http://toyspeed.blakjak.net/profiles/profile.php?id=1702
The Harder You Fall The Higher You Bounce!
bigfut
Re: Go faster mods?
Postby CozmoNz » Sun Feb 20, 2005 12:20 pm
bigfut wrote:Just bought a new Hiace, and wanted some thoughts on things to make it go faster, I realise its a diesel and its never going to be quick, but just after some ideas to give it a bit more pace. Cheers
is she turbo?
if not you can simply bolt a turbocharger onto a deisel, richen it up some (to make up for the compressed air), chuck a bit more boost in (8psi ish), and youll be away laughing.
mates mates mate etc has a safari which he bolted a turbo onto, runs 12psi. you have no idea how quickly this thing gets off its arse :).
Rayne For President!
CozmoNz
Postby Dr-X » Sun Feb 20, 2005 12:47 pm
Czo, you do realise that converting to turbo is a little more than 'bolting on a turbo', right? If you're after simple mods to make it a little quicker, just do the basics, as per any car. I would suggest that if you want a quick car, the deisel wasn't the way to go. I'd be looking at an engine conversion.
Dr-X
Postby deaf_rattle » Sun Feb 20, 2005 1:00 pm
only two things i see wrong with this
1 its a van
2 its diesel powered
sort those two things out and you might make some progress
Postby CozmoNz » Sun Feb 20, 2005 1:12 pm
Dr-X wrote:Czo, you do realise that converting to turbo is a little more than 'bolting on a turbo', right? If you're after simple mods to make it a little quicker, just do the basics, as per any car. I would suggest that if you want a quick car, the deisel wasn't the way to go. I'd be looking at an engine conversion.
they made deisel hiace vans >.> presuming its the same engine has the turbocharged ones (same block, different strokes to make up displacement / torque).
just goto a wreckers and grab the manifold's needed etc...
not that hard >.> costly yes, but what mods are free?
its a deisel, so um... i duno... only option is turbo the bitch
CozmoNz
Postby MetalupYoAss » Sun Feb 20, 2005 2:18 pm
Exhaust manifold with turbo >~$1000
Intercooler $200
Intercooler pipe work $200
sump modification + oil feed line $~100
downpipe + bigger exhaust atleast $500
thats atleast $2000 to get it turboed and its still going to be a slug
your so full of shit cozmo NZ stop talking out of your arse
MetalupYoAss
Postby ChaosAD » Sun Feb 20, 2005 2:53 pm
just use some octane booster and advance the ignition timing ay coz
ChaosAD
Postby Stealer Of Souls » Sun Feb 20, 2005 4:24 pm
Intake, exhaust. That's probably about it without doing silly things.
Saw an article on Autospeed where they did that to a Pajero I think it was. Made some improvement. Wasn't a flyer. But hey. Just discovered how good diesels are on hills with a van load of people!!!
'86 AE85.5 Levin
Stealer Of Souls
Postby CozmoNz » Sun Feb 20, 2005 4:50 pm
MetalupYoAss wrote:Exhaust manifold with turbo >~$1000
Intercooler $200
your so full of sh*t cozmo NZ stop talking out of your arse
cost me $235 for my intercooler, piping, turbocharger...
go down to a wreckers, i could pick the LOT up for around... 700ish?
i talk shit do i? least i dont pay 2k for a 700 job :P
Intercooler = stock, pipe work = stock.. turbo OMGOSH STOCK
sump modification... nick the sump off a hiace turbo... unless she comes from the block like my one... in which case ur $&#$% :P.
but you wouldnt rush in.
its a bloody deisel anyway.
CozmoNz
Postby bigfut » Sun Feb 20, 2005 5:05 pm
deaf_rattle wrote:only two things i see wrong with this
1 its a van
Yeah I realise this, but it has to be both of these coz its for a courier run, so yeah. Intake and exhaust seems the way to go, and someone told me open up the injectors? but i didnt think the nz hiace was injected??
bigfut
Postby Loudtoy » Sun Feb 20, 2005 5:11 pm
1 its a van
Well if it's anything like the diesel trucks i used to drive round wellington you open up the restrictions in the fuel lines/pump/injectors where ever the fuel flow is controlled on those motors and you make a bit more power!
Other than that yeah intake and exhaust is you only mods - mind you if you do an intake and exhaust you will really want to up the fuel a bit any way!
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby CozmoNz » Sun Feb 20, 2005 5:14 pm
1 its a van
well um... deisels are injected.... you cant carbie a deisel...
more air + more fuel = more power.
CozmoNz
Postby bigfut » Sun Feb 20, 2005 5:21 pm
CozmoNz wrote:
1 its a van
I see, so opening up the injectors could be an option too
bigfut
Postby ee904age » Sun Feb 20, 2005 7:06 pm
What they said. Its not really opening the injectors it the injector pump you wanna play with. Diesels respond even better to cold air than petrol engines do so get the coldest air you can into it, although this will be easier said than done in a van.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby strap-on » Sun Feb 20, 2005 7:25 pm
diesels go good with an exhaust too
the turbo hiaces are the shit, try find one of those engines, we have one at work and we wound the boost up a bit, nothing beats it up hills
strap-on
Users browsing this forum: Bing [Bot] and 21 guests
