Toyota Factory 2 port brake:
Postby hare » Sun Feb 20, 2005 11:44 am
how many model come with it?are they the same,I have been told the supercharge AE101 levin have it,AE101/AE111 superstrut levin have it,MR2 turbo have it?are they all the same???I mean the distance between the two bolt at the back,please help if you know,thanks
hare
Re: Toyota Factory 2 port brake:
Postby CozmoNz » Sun Feb 20, 2005 12:19 pm
hare wrote:how many model come with it?are they the same,I have been told the supercharge AE101 levin have it,AE101/AE111 superstrut levin have it,MR2 turbo have it?are they all the same???I mean the distance between the two bolt at the back,please help if you know,thanks
im assuming you ment 2 pot (a pot is a piston), caliper's
ae111 bz-g / v r had them, mr2's both turbo and non turbo (djsw20's mr2 has 2 pot on the front).
not sure about the older cars however.
and are they all the same? HIGHLY doubt it, no way will a Mr2 turbo and a levin have the same brakes...
and bolt on the back?
Rayne For President!
CozmoNz
Postby craigt » Sun Feb 20, 2005 5:50 pm
My Ae101 GTZ has the big 2 pot sliding calipers on the front.
Not a huge range of pad choices, but they work very well!
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby hare » Wed Feb 23, 2005 11:07 pm
have been told toyota factory two port can bolt on into my echo,but find that the one from AE111 is not bolt on,that's why want to know is there any other two port as well..... :cry:
hare
Postby Twolitre » Thu Feb 24, 2005 1:22 am
ST185 non widebody and some ST182/ST183's have twin piston front callipers, and so do the later ST202 Celica's and even the ST215 Caldinas as far as I know.
Twolitre
Postby hare » Tue Mar 01, 2005 12:29 am
thanks,but got some news from the ppl who did it said need adapter plate to fit AE111's one on the car,....
Twolitre wrote:ST185 non widebody and some ST182/ST183's have twin piston front callipers, and so do the later ST202 Celica's and even the ST215 Caldinas as far as I know.
hare
Users browsing this forum: No registered users and 45 guests
