HRT wrote:Buy my crappy old Mirage. I'll put a warrent and rego on it if ya like, motor was rebuild about 20 kms ago (not thousand, 20kms) but the car is a POS
Haha, I'll pass thanks. Has to be rear or four wheel drive...
matt dunn wrote:FYI,
The 1GGZE and 1GGTE engine's had rods and pistons that are a direct fit into a 4K, same bore size, same big end bearing size, and same distance from the centre of the crank to the top of the piston, and yes I have done that and they do fit.
Also,
using the 4K twin squish japanese pistons and the NZ 4k head you get a super low compression ratio that is ideal for boost, but still uses old 80's design N/a pistons.
Matt
pervert wrote:It is not getting a 4AGE...just don't want one...
matt dunn wrote:pervert wrote:It is not getting a 4AGE...just don't want one...
exactly, why would you want to put one of Toyota's most famous, most reliable and most cost efficient engines in your car.
pervert wrote:..............every second KE70 has a 4AGE in it, that makes me yawn...after all, it is MY car...
