how do i tell what version conrods i have
Postby R15 » Thu Mar 17, 2005 10:55 pm
my car (hack) a diesel caldina with a 2c had noist bearings, so i pulled them out, except even with my full model code there is 3 variations of beairngs.
i need to choose 1 2 or 3, there is 2 2 with another 2 stamped ontop but slightly above te other 2 on each bottom pat (that holds the conrod onto the crank.) does this mean its a version 2?
sorry, im crap with part names, but hopefully you get the idea
R15
Postby ee904age » Fri Mar 18, 2005 5:03 am
I could be wrong but I think version 1,2 & 3 are the description for oversized bearings? IE, to suit a reground crank. one of them is standard and the other two are bigger.
Hard to come up with the wording to explain it at this time of the day!
Mr Revhead?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby vvega » Fri Mar 18, 2005 11:28 am
its called a numbered bearing system
123 are for stock cranks to allow for tool wear on the crankshaft
genrally when you go oversize you are more accurate....
that is all
v
vvega
Postby Mr Revhead » Fri Mar 18, 2005 11:41 am
as vega...
measure your crank, find out if its still in spec, then 2s should be fine.
your local dealer should be able to provide you wit a photocopy from the relavant page from the manual that shows how to figure out the bearing sizes, and the crank tolerances etc
