Broken Central Locking
Postby Zeckle_1 » Wed Mar 23, 2005 9:43 am
I have a lilttle problem with my 1993 toyota levin, some one ran into the passangers door, so i got that fixed, but about 3 months after the crash my passangers door central locking stopped working. Ive had the door to bits and stuff like that so see what the problem is but there doesnt seem to be anything visually wrong.
But the even stranger thing is that it works sumtimes when the outside temperature gets to over 28 degrees.
Can any1 help??? :?
Zeckle_1
Postby BlakJak » Wed Mar 23, 2005 10:28 am
funny that youve identified a temperature, sure its not just a coincidence?
Take it in to the pro's, theyll sort it.. could be all sorts.
If its temp related it could be due to expansion but i wouldnt think the variation between ~20 and 28 deg would be enough to account for much
BlakJak
Postby Zeckle_1 » Wed Mar 23, 2005 1:42 pm
Yeah, i knew it would come down to that... but hey worth a try :)
Zeckle_1
Postby Dr-X » Wed Mar 23, 2005 1:50 pm
I'd just try replacing that motor. $25 or there abouts from Repco.
Dr-X
Postby matt dunn » Mon Mar 28, 2005 10:54 pm
Dr-X wrote:I'd just try replacing that motor. $25 or there abouts from Repco.
I'd agree with 1/2 that.
Probably the motor needs replacing,
but I was sure all the AE101's that i've done the motor has been part of the catch, and more than $25.
Matt
