GT4 20 wrote:In the good ol' days, most pads had wire running thought them so that when the pad got down to a minimum safe thickness, teh wire was 'broken' which illuminated a light on the dash telling the driver that the pads needed changing.
Problem is that people ignored the light (or even disconnected the bulb!) which is why these days, a metal strip is built into the pad which comes into contact with the rotor when the pad thickness is low. This way, the average motorist will realise that their pads need changing and for the erst, due to the awful noise, they simply can't ignore it![]()
Gary
Dr-X wrote:The pad squeaking is actually not caused by friction between the rotor and the pad (unless the pad is significantly worn), but between the pad backing and the caliper.
ROBODISCO_20v wrote:
Dr X you're a fcuking idiot
GT4 20 wrote:Dr-X wrote:The pad squeaking is actually not caused by friction between the rotor and the pad (unless the pad is significantly worn), but between the pad backing and the caliper.ROBODISCO_20v wrote:
Not often I agree with ROBODISCO_20v
Dr-X wrote:GT4 20 wrote:Dr-X wrote:The pad squeaking is actually not caused by friction between the rotor and the pad (unless the pad is significantly worn), but between the pad backing and the caliper.ROBODISCO_20v wrote:
And once again, someone is here to argue with me when they dont know the facts. I read a VERY good technical article put together from university research on the topic, which I wish I could find right now.
Dr-X wrote:WTF? There's nothing wrong with putting a spot of grease between the pad backing and the caliper/piston.
Perky wrote:how would anti-squeal shims stop the piston rotating?
