running 3sfe on 3sge ECU and loom?
Postby Liloss » Fri Apr 15, 2005 7:29 pm
would i be able to run a 3sfe on a 3sge ecu and loom? without swapping the heads? or what would be needed to make it run?
~~Liloss~~
Liloss
Postby Dr-X » Fri Apr 15, 2005 8:03 pm
Why would you want to do this?
Dr-X
Postby Adamal » Fri Apr 15, 2005 8:10 pm
I don't think it would be a good idea.
The G head is designed for more power higher up.
The F head is designed for more torque down low, driving round town and what not.
Now I'm no ECU expert, but seeing as it controls the fueling, it might end up too lean down low and too rich up high. Because it's programmed for the G head. Of course, I don't know how much allowance the ECU has for adding or subtracting extra fuel from the mixture is...
Postby Liloss » Fri Apr 15, 2005 8:40 pm
why would i want to do this? basically because i dont want to have to re-wire my st183 for a 3sfe from the 3sge. i can't find any 3sge's and i dont have much time. just forked out for a head gasket job and the typical POS engine smokes like a biarch and is only running on three cylinders and boils the water like crazy.
~~Liloss~~
Liloss
Postby Twolitre » Fri Apr 15, 2005 9:02 pm
It wont be ideal but should run ok, just make sure you use the 3SGE injectors.
Twolitre
