20v Pistons into 16v
Postby ee904age » Sat Apr 23, 2005 10:19 pm
Does anybody know what affect on the C/R putting silvertop rods and pistons into a 16v will have (if any).
Im getting a set off HRT and just need to know what head gasket thickness Im gonna use.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby ChaosAD » Sun Apr 24, 2005 7:13 pm
Why would you want to use 20v pistons in a 16v? :?
ChaosAD
Postby ee904age » Sun Apr 24, 2005 7:24 pm
why not? Im getting pistons and rods together, so I would prefer to use the newer pistons than use my 18 year old ones again.
90 SW20 N/A - Sold
ee904age
Postby Gavin » Sun Apr 24, 2005 7:48 pm
Do you know if the valves clear the 5-valve pistons?
ADMIN EDIT: stupidly large image removed
20v Powered AE92 wagon (20v turbo project)
78 280z Black Pearl Edition AutoX'er
Gavin
Postby ChaosAD » Sun Apr 24, 2005 8:41 pm
I would have thought that the silvertop ones would make less power in a 16v. If you want more copmpression then shave the head and use a trd gasket. maybe get some new pistons off mr revhead if the need be.
BTW too much compression and youll lose power with the stock ecu as youll have to retard the timing.
ChaosAD
20v pistons
Postby GOLDAE86 » Sun Apr 24, 2005 9:48 pm
Yes you can do that, ive done it to a mates car and am going to do it to my car as well. Had to put on an adjustable fuel pressure reg to allow for the raised comp ratio :D
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Re: 20v pistons
Postby ee904age » Mon Apr 25, 2005 12:22 am
oops
90 SW20 N/A - Sold
ee904age
Re: 20v pistons
Postby ee904age » Mon Apr 25, 2005 12:23 am
GOLDAE86 wrote:Yes you can do that, ive done it to a mates car and am going to do it to my car as well. Had to put on an adjustable fuel pressure reg to allow for the raised comp ratio :D
Thats what I wanted to hear!
The engine may be going F/I in the furure so I'd rather not do anything irreversible the the engine itself, such as shave the head. At least by rebuilding and fitting slightly higher comp pistons and a TRD gasket, its easy enough to swap the pistons to GZE ones and go turbo in the future.
Gavin wrote:Do you know if the valves clear the 5-valve pistons?
Thats another issue I wanted to clear up.
90 SW20 N/A - Sold
ee904age
