Hi there all, i just need some help and confirmation on some tech issues, as i want to get my project underway for my car.
i am planning to put a superchager into a 4AGE blacktop 20V. My friends been telling me supercharger has less less lag than turbo, and also it works better at higher revs. Is this true?
also, if i use my factory pistons, i can only run low boost. now, does tht mean i can only run low boost because the piston will not allow high boost, or does it mean that i "NEED" to run low boost or else i will blow my engine? must i change to low compression pistons? is so, anyone know where i could source some?
another question is it easy to fit a supercharger into a black top, i am planning on putting at SC-14 supercharger, which is bigger than the 4AGZE SC-12.
here is wht i am planning to do.
1) recon my engine and use forged pistons, and change to brand new heavy duty valve springs and valves.
2) acid dip the block: anyone know how much it will cost???
3) in the process of recon, i will do port polish too
4) fit supercharger
people may ask why i dun fit a turbo instead. well, thts just because i want to keep most of the car's characteristics. which is "high revs" unless my frds been telling me the wrong thing. then i probably won't even bother with the supercharger.
Cheers all for any advice.
