Cam removal from Y series engine
Postby UTERUS » Tue Apr 26, 2005 10:17 pm
How hard is it to remove the cam from my 2y, can i just whip it out the front of the block or does it involve taking the motor out?
Also who knows of a good place in auckland that do cam grinds.
Chur chur
Simon.
UTERUS
Postby Bling » Tue Apr 26, 2005 11:23 pm
just replace the whole engine :wink:
jokes 8)
Postby UTERUS » Wed Apr 27, 2005 8:42 pm
BZG|Bling wrote:just replace the whole engine :wink:
jokes 8)
Hey i would say the same to you, and your vvt light :lol:
UTERUS
Postby UTERUS » Wed Apr 27, 2005 8:43 pm
But yea, help me out. Someone must have worked on this dinasour of an engine.
UTERUS
Postby UTERUS » Thu Apr 28, 2005 9:54 pm
Anyone 8O
UTERUS
CAM
Postby JasonZE » Sat Apr 30, 2005 2:25 pm
You need to remove rocker cover and rocker shaft then push rods.
Then Im unsure if you can get the cam followers out through the top but i would say you should be able to then pull the cam out the front.
If you dont get the cam followers out the will prevent you getting the cam out as they drop down and hit the next lobe as you pull it out.
JasonZE
Real Life Mechanic
Postby UTERUS » Sun May 01, 2005 7:47 pm
I will probably be taking the head off to get "adjusted" at the same time so will this make the process easier?
Do i need to replace the head studs when i replace the head?
What else will i need to do when i put the cam back in and head on.
Cheers.
UTERUS
Postby UTERUS » Mon May 02, 2005 11:45 pm
Need some more info. How long will it take to get the head and cam out approx?
UTERUS
