Uprating Alternator - How much?
Postby Stealer Of Souls » Wed Apr 27, 2005 12:38 pm
What's available?
And how much?
'86 AE85.5 Levin
Stealer Of Souls
Postby NZ_AE86 » Wed Apr 27, 2005 8:52 pm
To run what? How much power do you need?
NZ_AE86
Postby event2 » Thu Apr 28, 2005 12:05 am
cant realy uprate an alternator u would just hav to find one the mounts in alright with a higher output.
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Postby Alex B » Thu Apr 28, 2005 12:06 am
always a price to pay when putting in a higher output alternator tho. More engine strain, more peddy.
Postby Malcolm » Thu Apr 28, 2005 12:39 am
you can actually get an alternator rewound to produce more current. Normally looking at atleast $400 including rebuild I think.
Incidentally SW20 MR2's have quite meaty alternators. Couldn't tell you exactly what the output is, but they are physically much bigger than a standard Toyota alternator, and although they would require a new mount to be made (only on one end though), they would be a reasonably simple upgrade. The reason they are so big is that they have to drive the electric power steering pump, which most Toyota's dont have
Postby Stealer Of Souls » Thu Apr 28, 2005 9:50 am
SW20 alternator... will keep that in mind...
Ummm... Was thinking about 120-150 amp I guess. Not really interested in a rewind. Something aftermarket.
Oh yeah.
4AGE AE85.5
Wanna upgrade alternator cause I'm now got an Electric Water Pump, as a side effect the heater in my car no longer works very well (non-continuous/non-constant water flow), so I either need another little water pump for the heater or make an electric heater system.
'86 AE85.5 Levin
Stealer Of Souls
Postby 1598cc » Thu Apr 28, 2005 11:36 am
could go buget as and chuck another one on... more for the engine to turn but wouldnt cost much if anything.
1598cc
Postby Stealer Of Souls » Thu Apr 28, 2005 3:26 pm
Yeah. Thought of that. But I think it might be more difficult to site another one rather than just modify mounts to fit a bigger one...
'86 AE85.5 Levin
Stealer Of Souls
Postby NZ_AE86 » Thu Apr 28, 2005 11:01 pm
There would have to be something wrong with your factory 4AGE Alternator for it to fall over under the load of a waterpump! They are pretty good! What trouble are you having? If you are just set on the idea then I have a high output Lexus one that will go on with few mods. 8)
NZ_AE86
Postby Stealer Of Souls » Fri Apr 29, 2005 8:49 am
Alternator isn't falling over. It handles fine (pump on adds 6A at max flow...).
It's cause my heater doesn't work very well anymore (flow issues due to electric waterpump) and I was wondering how to fix it.
I had two real options. A separate little water pump to circulate water through the heater core or making up some form of electric heater. I was thinking of the electric heater option but would have to get a bigger alternator to stand up to the potential current draw.
So this is just a pricing check.
'86 AE85.5 Levin
Stealer Of Souls
Postby matt dunn » Fri Apr 29, 2005 7:02 pm
Stealer Of Souls wrote:Alternator isn't falling over. It handles fine (pump on adds 6A at max flow...).
Electric heaters are a waste of time.
The only effective one I've seen was on a SAME tractor that was air cooled.
It has it's own alternator to run it and drew just under 100A to make hot air. It had to have battery cables running to and from the element.
If your elec water pump doesn't flow enough to run water thru the heater, does it flow enough thru the engine?
Matt
Postby ee904age » Fri Apr 29, 2005 8:47 pm
Civic Wholesale stock a wide range of new aftermarket alternators, most models come in a range of outputs. I havent got any contact details for them anymore but Im sure you can find a number somewhere.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby matt dunn » Sat Apr 30, 2005 2:32 pm
ee904age wrote:Civic Wholesale stock a wide range of new aftermarket alternators, most models come in a range of outputs. I havent got any contact details for them anymore but Im sure you can find a number somewhere.
Yes but they dont sell to the public.
Postby Muzzie » Mon May 02, 2005 12:52 am
Not sure whats out there, but I got a 200amp Hitachi alternator put on the Hiace at a cost of 900 dollars.
Pity it's STILL struggling :twisted:
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby Stealer Of Souls » Tue May 03, 2005 10:02 am
matt dunn wrote:Electric heaters are a waste of time.
I had funny suspicion that an electric heater setup wouldn't really work. A bathroom heater is usually around 1100-1200W, but in a car you can't realisitically make more than 500-600W without need stupid amounts of stuff. Oh well..
And yes my EWP flows plenty for the engine. It's the flow characteristics. It flows a lot less than the mechanical because it's maintaining the temperature rather than just pushing water. Basically when I boot it the heater works fine (pumps starts to flow more), and when i cruise it doesn't work that well (flow drops to low rate)...
'86 AE85.5 Levin
Stealer Of Souls
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
