skyline 4 pots on ae86??
Postby ae86racer39 » Sat Apr 30, 2005 11:13 pm
does anyone know if skyline gts-t 4 pot front calipers can be fitted to an ae86 while retaining the factory ae86 master cylinder??
ae86racer39
Postby Rick » Sun May 01, 2005 10:06 am
Yes gts-t 4 pot front calipers can be fitted to an ae86 but you will need to use the larger master cylinder from the gts-t or other vehicle. I personally think the skyline brakes are a bit of an overkill but if you really want to do it, it can be done.
ae86
Postby crispy'86 » Sun May 01, 2005 6:45 pm
Why not settle for metal king pads?? I'm running them in my ae86, they are really good when warm (doesn't take much to heat them up) and pull the car up quite alot faster than with std brakes
crispy'86
Postby Tukumi » Mon May 02, 2005 12:29 am
Hey, ive done what your wanting to do.
I used cressida struts, and the gtst calipers bolt straight on, but i also used z31 300zx hubs and discs to get five stud also, ill take some better pics tomorrow.
Phil
AE85 4AGTE, 11.9@115mph <--Watch this space 229kw at the wheels ***sold***
WWW.NZEFI.COM
WWW.DORIMONS.COM
Tukumi
Postby fangsport » Mon May 02, 2005 8:30 pm
Phil, did you go to the 5-stud to get better access to larger rims, or to change the offset to accommodate the bigger discs. the reason i ask , i that I had a fleeting glance at fitting 4-pot Skyline calipers to the TA63 strut , but had serious clearance issues,and was wondering if it would be easily overcome with a more FWD offset?
fangsport
Postby ChaosAD » Mon May 02, 2005 9:47 pm
What about ae101 two pot callipers?
ChaosAD
Postby fangsport » Mon May 02, 2005 10:04 pm
ChaosAD wrote:What about ae101 two pot callipers?
are the AE101 calipers side-by-side 2-pots or opposing 2-pots?
fangsport
Postby ChaosAD » Tue May 03, 2005 1:15 pm
Side by side as far as I know. Ive heard of people fitting them to other FWD corolla/levin/trueno's but dont know abuot the RWD variants
ChaosAD
