illicit wrote:I got the whole motor from a smashy one so everything i need is there the only problem is the leg out of bed otherwise i would have jst swapped the motor over. Have you done this swap before HRT?
Yeah, just tidying the wiring up now and modifying the exhaust manifold from my 16V to fit on the 20V head. Oh yeah, you'll need to do that too
Wasn't enough meat on the flange to just slot them as people say you can do but I'm not using a standard manifold.
If you've got all of both engines then you should haven't any trouble, probably use either head gasket (I'm using the 16V one as I bought the overhaul kit for the 4AGZE before being offered the 20V head). Other stuff that you need that isn't in a 16V kit is the inlet cam oil seal, rocker cover gaskets, spark plug seals and.... something else I cant remember. Not too sure about spark plug leads as yet since I'm trying to use the GZE coil packs which mean that the silvertop leads (which you'll need 20V leads for that head) dont actually plug into the coil packs. If you're sticking with a distributor then this wont be an issue though.
Just ask if there is anything you need to know.
