Does anyone have any good links to sites on tuning an aftermarket ecu with alpha-N (TPS) and Alpha-N/Speed density (TPS/MAP).
Cant use map due to big cams and Quads.
Thanks,
The tricky part with tuning alpha-N is working out where the effective WOT is. It is a very non-linear relationship and depends critically on the sizing of the throttle body.
??Drifter4ag wrote:eayh ?
ChaosAD wrote:I know that 'stoich' isnt preferrable for power etc, but doesnt the factory ecu sit on that ratio when the car is in closed loop? ie all the time except idle and WOT. its only till I get it on the dyno anyhow
