1993-4 Camry V6 cam settings
Postby andyztouring » Mon May 16, 2005 11:40 pm
I`ve got a 1993 V6 camry(3VZ-FE) with motor in bits,recond block etc, now I need cam shaft timing settings,where all the dots go etc.Diagrams would be great.Any help would be much appreciated.
andyztouring
Postby Mr Revhead » Tue May 17, 2005 5:23 pm
hey got this sorted? we'll have that info if your still stuck....
will need to know what its out of
library
Postby andyztouring » Tue May 17, 2005 7:59 pm
I went into the library tonite and found the info.photocopied it,hopefully will run right now once belt cogs are adjusted. Thanks for your offer of help.Cheers Andy
andyztouring
Postby 10k 20v » Wed May 18, 2005 12:01 am
make sure you pre load the anti back-lash sproket or it will rattle it's tits off, if it had tits
10k 20v
yeah
Postby andyztouring » Wed May 18, 2005 8:22 am
I did the preload sprocket,knew about that,one timing belt sprocket goes on with the flange to the inside,the other goes to the outside,this tripped me up!!!!!but at least I don`t have to reset the cams.
andyztouring
