Ive just put the silvertop pistons and rods into my bigport redtop, and Huston, we have a problem.
The bigends havent been torqued up but.... when I sit the head on without a gasket and turn the crank, the pistons are tapping the head
This doesnt happen with the gasket on (stock gasket), but the head is also not bolted on.
What I was thinking is, with the head torqued up and the gasket compressed this may cause a problem.
I will definately be putting plasticine (sp?) on the pistons and doing a test before running it, but if it turns out the wont hit, is it still too close to be safe??
EDIT: I havent got to the compression ratio yet, one hurdle at a time is one too many!!!!
